07-13-2011 06:33 AM - edited 03-04-2019 12:58 PM
I have seen this topology (attached) in Cisco best practice datacenter design.My question is, if your two DC are connected over layer2 links then why you would disable BPDU filter ?
We do have same topology ,Two DC's connected over layer2 links(10+10G) in one vPC.
07-13-2011 07:13 AM
In general, the BPDUFilter feature is used to split a (formerly) single STP domain into two independent STP domains so that each of them can have its own set of spanning trees, roots and active links, and topology changes in one domain do not propagate to the other domain, neither do they influence it. This is done to prevent one datacenter topology from influencing the other datacenter.
Of course, activating the BPDU FIlter effectively disables STP on the links configured with this feature. A great care has to be then taken to make sure that no switching loops ensue as a result.
Can you post the URL to the design document?
Best regards,
Peter
07-13-2011 08:49 AM
this looks like a nexus DC design.
some of the advanced features of nexus requires that STP is disabled
07-15-2011 08:43 AM
Yes it is from Nexus DC design, but what advanced feature required STP disabled?
Thanks .
