Branch Office Shared Internet NAT Configuration
JamesLilley1746
  • Good afternoon everyone, my organization has added a Branch Office.
  • I wish to have all of the internet traffic for the Branch Office flow through the HQ NAT Router.
  • I have set up a working DMVPN with dynamic routing using eigrp (see the attached image).
  • Routing is working on all Routers,
    show ip route
    command lists all subnets, I can
    ping
    and traceroute any local address in either LAN.
  • NAT is working for the Headquarters
    LAN 172.16.5.0
    however NAT is not working for the Branch Office
    LAN 172.16.4.0
  • I try to generate
    ping
    traffic from the Branch Office LAN to the internet and nothing displays when
    debug ip nat
    is enabled on the HQ NAT Router, nor does
    show ip nat translations
    show any traffic to the Branch Office LAN
  • I set up this same topology in Cisco Modeling Labs and NAT works fine for the Branch Office LAN, although I admit CML cannot replicate the underlay of a DMVPN in a production environment
  • Please review the NAT configuration in the attached image and advise.
2 Accepted Solutions
IOU5#show run
hostname IOU5
interface Ethernet0/0
ip address 200.0.0.5 255.255.255.0
ip nat outside
ip virtual-reassembly in
interface Ethernet1/1
ip address 10.0.0.5 255.255.255.0
ip nat inside
router eigrp 5
network 10.0.0.0 0.0.0.255
redistribute static metric 100 100 255 1 1500
ip nat inside source list 1 interface Ethernet0/0 overload
ip route 0.0.0.0 0.0.0.0 200.0.0.6
access-list 1 permit 3.3.3.3
access-list 1 permit 2.2.2.2
IOU1#show run
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key mhm address 120.0.0.3
crypto isakmp key mhm address 0.0.0.0
crypto ipsec transform-set mhm esp-des
mode tunnel
crypto ipsec profile mhmspoke
set transform-set mhm
crypto map mhmtunnel 10 ipsec-isakmp
set peer 120.0.0.3
match address 100
interface Tunnel0
ip address 5.0.0.1 255.255.255.0
no ip redirects
no ip next-hop-self eigrp 5
no ip split-horizon eigrp 5
ip nhrp map multicast dynamic
ip nhrp network-id 5
tunnel source Ethernet0/0
tunnel mode gre multipoint
tunnel key 5
tunnel protection ipsec profile mhmspoke
interface Tunnel1
ip address 15.0.0.1 255.255.255.0
tunnel destination 120.0.0.3
ip address 100.0.0.1 255.255.255.0
ip address 10.0.0.1 255.255.255.0
router eigrp 5
network 5.0.0.0 0.0.0.255
router eigrp 15
network 15.0.0.0 0.0.0.255
ip forward-protocol nd
ip route 110.0.0.2 255.255.255.255 100.0.0.4
ip route 120.0.0.3 255.255.255.255 100.0.0.4
access-list 100 permit gre host 15.0.0.1 host 15.0.0.3
access-list 100 permit gre host 100.0.0.1 host 120.0.0.3
IOU2#show running-config
hash md5
crypto isakmp key mhm address 100.0.0.1
mode tunnel
! Incomplete
set peer 100.0.0.1
match address 100
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Tunnel0
ip address 5.0.0.2 255.255.255.0
no ip redirects
ip nhrp map 5.0.0.1 100.0.0.1
ip nhrp map multicast 100.0.0.1
ip nhrp nhs 5.0.0.1
tunnel source Ethernet0/1
tunnel key 5
interface Ethernet0/1
ip address 110.0.0.2 255.255.255.0
router eigrp 5
network 2.2.2.2 0.0.0.0
ip route 100.0.0.1 255.255.255.255 110.0.0.4
  • Good Morning, I have reviewed your Lab config and applied the relevant changes to my network (see attached image)
  • I am happy to report that NAT is now working in the Branch Office LAN while all internet traffic flows through the Headquarters NAT Router as intended.
  • Thank you for your time and efforts.
27 Replies 27
Hi @JamesLilley1746
  • I try to generate
    ping
    debug ip nat
    show any traffic to the Branch Office LAN"
Did you try to remote the
default route
on Branch side? I believe the traffic is leaving through ISP2
  • Thank you for the quick response.
  • If I
    ping 8.8.8.8
    from a PC in the Branch Office the
    ping
    fails.
  • However if I
    ping 8.8.8.8
    from the Branch Office Router the
    ping
    succeeds and a traceroute shows it that does leave through the ISP2.
  • I do not know what you mean by remote the
    default route
    Did your mean remove the
    default route
Hi @JamesLilley1746  Yes I meant remove! haha...it was a typo, sorry.
  If you run a tracert from the PC, it probably are going to ISP2, right?  I believe the
default route
is taking preference over the EIGRP
The reason the
ping
fail from PC but not the router is probably because you have no NAT on the Branch Router towards ISP 2. When you
ping
from the router itselt the ISP2 knows how to reply but when you
ping
from the PC, the  ISP2 does not know the
network 172.16.4.0
and that´s why the response from 8.8.8.8 does not come.
  • OK thanks for the clarification.
  • So if I remove the
    default route
    on the Branch Office router:
    no ip route 0.0.0.0 0.0.0.0 32.221.21.150
       will the router still function?  I thought there had to be a
    default route
    for routing to function.
  • How about changing it to:
    ip route 0.0.0.0 0.0.0.0 GigabithEthernet 0/0/1
    default route
    default route
 If you want to sent the internet traffic towards ISP1 which I believe it on HQ, you can not have a
default route
pointing to ISP2. Yes, the router will function.  If you need to send any traffic to ISP2, you can add specific route to ISP2 or you can stablish a routing protocol between Router branch and ISP2.
Dont configure
default route
like that. Use IP address instead.
  • That did not work.
  • As soon as I removed the
    default route
    I lost connection with the Branch Office Router.
  • I will have to wait until tomorrow to re establish connection.
Then you access was through the ISP2?
 But do you have access to HQ?  If you access the router on HQ and try to access the router on Branch it should work, they have direct connection, dont they?
  • I was connected to the Branch Office Router through the DMVPN Tunnel connected to the WAN Router.
  • I currently have access to the HQ WAN Router and HQ NAT Router
    default route
    on the Branch Router the connection went down and I have not been able to reconnect.
  • I cannot
    ping or ssh
    into the Branch Router. I will have to go onsite tomorrow and connect directly.
Sorry to hear that. If I knew you could lost access I would suggest to you add the commamd "
reload in x(time)
and not save the config.
 This way whe  you lost access you just need to wait X time.
 Another option is config archive and setup rollback
What you can do tomorrow is return the
default route
and create a static route to 8.8.8..8 sending to HQ just for test purpose. As soon as you figure out how it works, you remove the
default route
and add it pointing to HQ.
 But the conclusion to me is, with default routing sending to ISP2, the internet traffic will not go to HQ.
this need some work, I will share with you the way to config but before that why you use
default route
in branch ?
  • Thank you for the response
  • To answer your question about the
    default route
    I thought a router had to have a
    default route
    in order to function.
  • So if I remove the the
    default route
    on the Branch Router:
       and do not replace it with anything else the router will still function?
two steps here
first default information in Hub toward Spoke
in Spoke you need static route for
Hub IP (tunnel)
toward ISP2
that it
One more note, you need to add Spoke Lan subnet in acl of NAT overload of hub.
MHM
  • OK to clarify, you want me to add the Spoke (I assume you mean Branch Router)
    LAN subnet 172.16.4.0
    to the ACL named NAT on the HUB (I assume you mean WAN Router)?
  • There is no ACL or NAT overload statement on the HUB, only on the HQ NAT Router, did you mean the HQ NAT Router?
  • If so that already exists. See below
ip access-list extended NAT
   permit ip 172.16.4.0 0.0.255 any
   permit ip 172.16.5.0 0.0.0.255 any
