11-15-2020 08:21 AM - edited 11-15-2020 08:27 AM
Experts,
After all reading, Googling, and trial/error I can take, I still can't get a DLNA multicast announcement to stream to a branch office DLNA receiver.
Goal: DLNA TV receivers at branch offices receive a DLNA multicast announcement from a DLNA media server at HQ/Hub.
Topology:
-The branches are connected to the HQ/Hub via a DMVPN tunnel and EIGRP. One branch is currently being NAT'd so it's spoke to spoke gets routed through hub.
The HQ/HUB router is the RP for the multicast sparse/Dense and the DR for each segment.
Connectivity looks like:
SERVER->C3560G <--L3--> 2921 <(DMVPN TUNNEL)> 1921 (Branch 1) / 819 (Branch 2)
The C3560G is acting as a core switch doing L3.
The 2921 is the HQ FW and DMVPN Hub.
The branches use 2921s or 819s.
The media server is 172.20.16.201
(Config pieces attached)
The stream *seems* to show up on the 2921 HQ/HUB router:
HQ/HUB# show ip mroute 239.255.255.250
(*, 239.255.255.250), 15:24:19/00:03:24, RP 172.20.19.246, flags: S
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list:
Tunnel0, Forward/Sparse-Dense, 02:24:01/00:03:24
GigabitEthernet0/0, Forward/Sparse-Dense, 13:48:56/00:03:03
(172.20.42.5, 239.255.255.250), 00:00:05/00:03:24, flags: T
Incoming interface: Tunnel0, RPF nbr 172.20.254.3
GigabitEthernet0/0, Forward/Sparse-Dense, 00:00:05/00:03:24
(172.20.16.201, 239.255.255.250), 15:24:19/00:02:41, flags:
Incoming interface: GigabitEthernet0/0, RPF nbr 172.20.19.249
* I say seems because I still don't totally understand the multicast routing even from all the reading about it.
This makes me think there is no problem between the server/core switch and the HQ/Hub router. Not sure. It looks like the stream is being sent out the tunnel interfaces towards the branches.
The steam not showing up on the branches:
BRANCH 1 819# show ip mroute 239.255.255.250
(*, 239.255.255.250), 20:04:19/00:02:53, RP 172.20.19.246, flags: SJCL
Incoming interface: Tunnel0, RPF nbr 172.20.254.2
GigabitEthernet0/0, Forward/Sparse-Dense, 13:51:13/00:02:53
BRANCH 2 2921# show ip mroute 239.255.255.250
(*, 239.255.255.250), 13:26:28/stopped, RP 172.20.19.246, flags: SJCLF
Vlan420, 172.20.42.254, Forward/Sparse-Dense, 00:08:50/00:02:08
Vlan420, 172.20.42.5, Forward/Sparse-Dense, 00:33:10/00:01:01
Vlan320, Forward/Sparse-Dense, 13:26:28/00:02:00
(172.20.42.5, 239.255.255.250), 00:00:49/00:02:40, flags: LFT
Incoming interface: Vlan420, RPF nbr 0.0.0.0
Tunnel0, Forward/Sparse-Dense, 00:00:49/00:02:40
Vlan320, Forward/Sparse-Dense, 00:00:49/00:02:10
Vlan420, 172.20.42.5, Forward/Sparse-Dense, 00:00:49/00:02:10
Vlan420, 172.20.42.254, Forward/Sparse-Dense, 00:00:49/00:02:10
Brach 2 has a device also broadcasting announcements. In both cases, the announcement from the media server never seems to make it, and is not detected by the receiver. If the receiver is connected to the HQ subnet of the media server, it's naturally immediately detected.
I've tried everything I could think of to make this work.
Question 1: Do I need to create a mapping on the RP? If so, how?
Question 2: What am I doing wrong or missing?
Thanks much!
11-15-2020 08:35 AM
did you configure the mapping agent on the hub router, something like below ?
interface loopback 0
ip pim sparse-dense-mode
ip pim send-rp-discovery loopback 0 scope 10
11-15-2020 08:46 AM - edited 11-15-2020 08:46 AM
Yes sir,
HQ/HUB:
interface Loopback0
description ** ROUTER ID **
ip address 172.20.19.246 255.255.255.255
ip nat inside
ip virtual-reassembly in
zone-member security LAN
end
My RP Commands are only available in Global:
ip pim bidir-enable
ip pim autorp listener
ip pim send-rp-announce Loopback0 scope 10
ip pim send-rp-discovery Loopback0 scope 10
11-15-2020 09:15 AM
that part looks good. I somewhere remember that you have to put the command 'ip pim nbma-mode' on the tunnel interface of the hub router, can you give that a try ?
11-15-2020 10:21 AM
I tested it, doesn't seem to make a difference.
11-15-2020 08:48 AM - edited 11-15-2020 08:55 AM
Config Info:
! CORE SWITCH WITH MEDIA SERVER
interface Vlan165
description ** GATEWAY of Media Server **
ip address 172.20.16.254 255.255.255.128
ip helper-address 172.20.16.1
ip igmp version 3
interface GigabitEthernet0/48
description ** ROUTER UPLINK to 2921/HQ HUB Router **
no switchport
ip address 172.20.19.249 255.255.255.248
mls qos trust dscp
flowcontrol receive desired
spanning-tree portfast
spanning-tree bpdufilter enable
ip multicast-routing distributed
ip pim bidir-enable
! HQ/HUB ROUTER 2921
interface GigabitEthernet0/0
description ** Downlink to Core Switch **
ip address 172.20.19.254 255.255.255.248
ip pim dr-priority 10
ip nat inside
ip traffic-export apply TRAFFIC_EXPORT
duplex auto
speed auto
service-policy output POLICYMAP_WAN-EGRESS-QUEUING
end
interface Tunnel0
description DMVPN
bandwidth 100000
bandwidth qos-reference 100000
ip address 172.20.254.2 255.255.255.0
no ip redirects
ip mtu 1400
no ip next-hop-self eigrp 1
no ip split-horizon eigrp 1
ip nat inside
ip nhrp authentication CNDMNTCS
ip nhrp network-id 1
ip nhrp holdtime 300
ip summary-address eigrp 1 172.20.16.0 255.255.248.0
ip tcp adjust-mss 1360
delay 100
nhrp group DMVPN-QOS_100MBPS
nhrp map group DMVPN-QOS_100MBPS service-policy output POLICYMAP_DMVPN-100MBPS-LINE-RATE
nhrp map group DMVPN-QOS_60MBPS service-policy output POLICYMAP_DMVPN-60MBPS-LINE-RATE
qos pre-classify
tunnel source GigabitEthernet0/1
tunnel mode gre multipoint
tunnel key 1
tunnel path-mtu-discovery
tunnel protection ipsec profile IPSEC-PROFILE_DMVPN
end
ip pim bidir-enable
! Branch 1 - 819
interface Vlan420
description Default gateway for Germany LAN
ip address 172.20.42.254 255.255.255.0
no ip proxy-arp
ip nat inside
ip policy route-map ROUTEMAP_TV-SUBNET
ip igmp join-group 239.255.255.250 ! Attempting to get stream
end
interface Tunnel0
description DMVPN
bandwidth 100000
ip address 172.20.254.3 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp group DMVPN-QOS_100MBPS
ip nhrp map group DMVPN-QOS_100MBPS service-policy output POLICYMAP_DMVPN-100MBPS-LINE-RATE
ip nhrp map group DMVPN-QOS_60MBPS service-policy output POLICYMAP_DMVPN-60MBPS-LINE-RATE
ip nhrp nhs dynamic nbma gateway.FQDN.com multicast
ip summary-address eigrp 1 172.20.32.0 255.255.248.0
delay 100
qos pre-classify
tunnel source Dialer1
tunnel key 1
end
ip pim bidir-enable
! Branch 2 - 2921
ip address 172.20.48.254 255.255.255.128
ip nat inside
ip igmp version 3
duplex auto
speed auto
end
interface Tunnel0
description DMVPN
bandwidth 60000
bandwidth qos-reference 60000
ip address 172.20.254.4 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp group DMVPN-QOS_60MBPS
ip summary-address eigrp 1 172.20.48.0 255.255.255.0
ip tcp adjust-mss 1322
delay 100
tunnel key 1
end
ip pim bidir-enable
Show Output
show ip pim neighbor
172.20.19.254 GigabitEthernet0/48 16:53:54/00:01:16 v2 10/ DR B S P G
show ip pim rp
Group: 239.255.255.251, RP: 172.20.19.246, v2, uptime 16:37:19, expires 00:02:21
Group: 239.255.255.250, RP: 172.20.19.246, v2, uptime 16:37:19, expires 00:02:21
Group: 239.255.3.22, RP: 172.20.19.246, v2, uptime 16:37:19, expires 00:02:21
Group: 224.0.1.178, RP: 172.20.19.246, v2, uptime 16:37:19, expires 00:02:21
show ip pim rp mapping
Group(s) 224.0.0.0/4
RP 172.20.19.246 (?), v2v1
Info source: 172.20.19.246 (?), elected via Auto-RP
Uptime: 16:37:44, expires: 00:02:54
show ip mroute
(*, 239.255.255.251), 16:01:04/stopped, RP 172.20.19.246, flags: SJCF
Incoming interface: GigabitEthernet0/48, RPF nbr 172.20.19.254
Vlan165, Forward/Sparse-Dense, 16:01:04/00:02:51
(172.20.16.207, 239.255.255.251), 16:01:04/00:02:58, flags: PFT
Incoming interface: Vlan165, RPF nbr 0.0.0.0
Outgoing interface list: Null
(*, 239.255.255.250), 16:01:02/stopped, RP 172.20.19.246, flags: SJCF
Vlan165, Forward/Sparse-Dense, 14:25:39/00:02:52
(172.20.16.156, 239.255.255.250), 03:25:24/00:02:18, flags: PFT
Incoming interface: Vlan165, RPF nbr 0.0.0.0, Registering
(172.20.16.131, 239.255.255.250), 15:24:08/00:01:48, flags: PFT
(172.20.16.201, 239.255.255.250), 16:01:02/00:02:57, flags: FT
GigabitEthernet0/48, Forward/Sparse-Dense, 03:00:45/00:02:57
(*, 239.255.3.22), 16:00:39/00:02:51, RP 172.20.19.246, flags: SJC
Vlan165, Forward/Sparse-Dense, 16:00:39/00:02:51
(*, 224.0.1.39), 16:40:28/stopped, RP 0.0.0.0, flags: DC
GigabitEthernet0/48, Forward/Sparse-Dense, 16:40:28/stopped
(172.20.19.246, 224.0.1.39), 00:00:06/00:02:53, flags: PT
(*, 224.0.1.40), 16:42:30/stopped, RP 0.0.0.0, flags: DCL
GigabitEthernet0/48, Forward/Sparse-Dense, 16:42:30/stopped
Loopback0, Forward/Sparse-Dense, 16:42:30/stopped
(172.20.19.246, 224.0.1.40), 16:38:28/00:02:17, flags: LT
Loopback0, Forward/Sparse-Dense, 16:38:28/stopped
(*, 224.0.1.178), 16:00:38/00:02:48, RP 172.20.19.246, flags: SJC
Vlan165, Forward/Sparse-Dense, 16:00:38/00:02:48
show ip igmp groups
239.255.255.251 Vlan165 16:55:23 00:02:08 172.20.16.162
239.255.255.250 Vlan165 14:26:23 00:02:09 172.20.16.152
239.255.3.22 Vlan165 16:55:23 00:02:08 172.20.16.162
224.0.1.39 GigabitEthernet0/48 16:40:05 00:02:57 172.20.19.254
224.0.1.40 Loopback0 16:57:20 00:02:48 172.20.19.244
224.0.1.178 Vlan165 16:55:23 00:02:05 172.20.16.251
172.20.19.249 GigabitEthernet0/0 16:58:07/00:01:15 v2 1 / B S P G
172.20.254.3 Tunnel0 13:49:17/00:01:21 v2 1 / B S P G
172.20.254.4 Tunnel0 1d14h/00:01:36 v2 1 / B S P G
show ip pim rp
Group: 239.255.255.251, RP: 172.20.19.246, next RP-reachable never
Group: 239.255.255.250, RP: 172.20.19.246, next RP-reachable never
Group: 239.255.3.22, RP: 172.20.19.246, next RP-reachable never
Group: 224.0.1.178, RP: 172.20.19.246, next RP-reachable never
Uptime: 16:41:28, expires: 00:02:55
show ip mroute
(*, 239.255.255.251), 16:04:15/00:02:35, RP 172.20.19.246, flags: S
GigabitEthernet0/0, Forward/Sparse-Dense, 16:03:16/00:02:35
(172.20.16.207, 239.255.255.251), 16:04:15/00:02:02, flags: P
(*, 239.255.255.250), 16:04:13/00:02:43, RP 172.20.19.246, flags: S
Tunnel0, Forward/Sparse-Dense, 03:03:55/00:02:43
GigabitEthernet0/0, Forward/Sparse-Dense, 14:28:50/00:02:35
(172.20.42.5, 239.255.255.250), 00:00:46/00:02:43, flags: T
GigabitEthernet0/0, Forward/Sparse-Dense, 00:00:46/00:02:43
(172.20.32.32, 239.255.255.250), 00:01:29/00:02:06, flags: T
GigabitEthernet0/0, Forward/Sparse-Dense, 00:01:29/00:03:01
(172.20.16.201, 239.255.255.250), 16:04:13/00:01:47, flags:
(*, 239.255.3.22), 16:03:50/00:02:59, RP 172.20.19.246, flags: S
GigabitEthernet0/0, Forward/Sparse-Dense, 16:03:50/00:02:59
(*, 224.0.1.39), 16:43:39/stopped, RP 0.0.0.0, flags: DCL
Loopback0, Forward/Sparse, 16:42:33/stopped
Tunnel0, Forward/Sparse-Dense, 16:43:39/stopped
GigabitEthernet0/0, Forward/Sparse-Dense, 16:43:39/stopped
(172.20.19.246, 224.0.1.39), 16:43:39/00:02:43, flags: LT
Incoming interface: Loopback0, RPF nbr 0.0.0.0
Tunnel0, Forward/Sparse-Dense, 03:44:05/stopped
GigabitEthernet0/0, Forward/Sparse-Dense, 16:42:33/stopped
(*, 224.0.1.40), 3d10h/stopped, RP 0.0.0.0, flags: DCL
Loopback0, Forward/Sparse, 21:11:38/stopped
Tunnel0, Forward/Sparse-Dense, 1d14h/stopped
GigabitEthernet0/0, Forward/Sparse-Dense, 16:59:45/stopped
(172.20.19.246, 224.0.1.40), 16:41:39/00:02:02, flags: LT
Tunnel0, Forward/Sparse-Dense, 16:41:39/stopped
GigabitEthernet0/0, Forward/Sparse-Dense, 16:41:39/stopped
(*, 224.0.1.178), 16:03:49/00:03:20, RP 172.20.19.246, flags: S
GigabitEthernet0/0, Forward/Sparse-Dense, 16:03:49/00:03:20
! Branch 1 - 819
show ip pim rp
Group: 239.255.255.250, RP: 172.20.19.246, uptime 13:51:42, expires 00:02:34
Uptime: 13:52:01, expires: 00:02:16
show ip mroute
(*, 239.255.255.250), 13:58:00/stopped, RP 172.20.19.246, flags: SJCLF
Vlan420, Forward/Sparse-Dense, 00:12:27/00:02:31
Vlan420, Forward/Sparse-Dense, 00:13:25/00:02:31
Vlan420, Forward/Sparse-Dense, 00:21:24/00:02:31
Vlan320, Forward/Sparse-Dense, 13:58:00/00:02:33
(172.20.42.5, 239.255.255.250), 00:02:39/00:00:50, flags: LFT
Tunnel0, Forward/Sparse-Dense, 00:02:39/00:02:47
Vlan320, Forward/Sparse-Dense, 00:02:39/00:02:33
(172.20.32.32, 239.255.255.250), 00:03:22/00:00:13, flags: LFT
Incoming interface: Vlan320, RPF nbr 0.0.0.0, Registering
Tunnel0, Forward/Sparse-Dense, 00:03:22/00:03:08
Vlan420, Forward/Sparse-Dense, 00:03:22/00:02:31
(*, 224.0.1.39), 14:01:37/stopped, RP 0.0.0.0, flags: DC
Tunnel0, Forward/Sparse-Dense, 14:01:37/stopped
(172.20.19.246, 224.0.1.39), 13:54:13/00:01:44, flags: PT
(*, 224.0.1.40), 3d09h/stopped, RP 0.0.0.0, flags: DCL
Tunnel0, Forward/Sparse-Dense, 3d09h/stopped
(172.20.19.246, 224.0.1.40), 13:53:11/00:02:07, flags: PLT
show ip igmp groups
239.255.255.250 Vlan420 09:10:59 00:02:06 172.20.42.5
239.255.255.250 Vlan320 3d10h 00:02:08 172.20.32.32
224.0.1.39 Tunnel0 14:02:02 00:02:07 172.20.254.2
224.0.1.40 Tunnel0 3d09h 00:02:04 172.20.254.3
! Branch 2 - 2921
show ip pim rp
Group: 239.255.255.250, RP: 172.20.19.246, uptime 16:42:03, expires 00:02:35
Uptime: 16:42:14, expires: 00:02:24
show ip mroute
(*, 239.255.255.250), 20:36:06/00:02:08, RP 172.20.19.246, flags: SJCL
GigabitEthernet0/0, Forward/Sparse-Dense, 14:23:00/00:02:08
(*, 224.0.1.39), 16:43:16/stopped, RP 0.0.0.0, flags: DC
Tunnel0, Forward/Sparse-Dense, 16:43:16/stopped
(172.20.19.246, 224.0.1.39), 16:42:23/00:01:47, flags: PT
(*, 224.0.1.40), 3d03h/stopped, RP 0.0.0.0, flags: DCL
(172.20.19.246, 224.0.1.40), 16:42:23/00:02:17, flags: PLT
show ip igmp groups
239.255.255.250 GigabitEthernet0/0 14:23:13 00:02:57 172.20.48.138
224.0.1.39 Tunnel0 16:43:29 00:02:27 172.20.254.2
224.0.1.40 Tunnel0 1d14h 00:02:26 172.20.254.4
11-15-2020 10:24 AM
Debug on the HUB
deb ip pim 239.255.255.250
Nov 15 18:23:20.155: PIM(0): Received v2 Join/Prune on Tunnel0 from 172.20.254.3, to us
Nov 15 18:23:20.155: PIM(0): Join-list: (*, 239.255.255.250), RPT-bit set, WC-bit set, S-bit set
Nov 15 18:23:20.155: PIM(0): Update Tunnel0/172.20.254.3 to (*, 239.255.255.250), Forward state, by PIM *G Join
Nov 15 18:23:20.159: PIM(0): Update Tunnel0/172.20.254.3 to (172.20.16.201, 239.255.255.250), Forward state, by PIM *G Join
CARM-GATEWAY#
Nov 15 18:23:21.527: PIM(0): Received v2 Join/Prune on Tunnel0 from 172.20.254.4, to us
Nov 15 18:23:21.527: PIM(0): Join-list: (*, 239.255.255.250), RPT-bit set, WC-bit set, S-bit set
Nov 15 18:23:21.527: PIM(0): Update Tunnel0/172.20.254.4 to (*, 239.255.255.250), Forward state, by PIM *G Join
Nov 15 18:23:21.527: PIM(0): Update Tunnel0/172.20.254.4 to (172.20.16.201, 239.255.255.250), Forward state, by PIM *G Join
CARM-GATEWAY#
Nov 15 18:23:23.223: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.250
CARM-GATEWAY#
Nov 15 18:23:25.223: PIM(0): Insert (172.20.16.201,239.255.255.250) join in nbr 172.20.19.249's queue
Nov 15 18:23:25.223: PIM(0): Building Join/Prune packet for nbr 172.20.19.249
Nov 15 18:23:25.223: PIM(0): Adding v2 (172.20.16.201/32, 239.255.255.250), S-bit Join
Nov 15 18:23:25.223: PIM(0): Send v2 join/prune to 172.20.19.249 (GigabitEthernet0/0)
CARM-GATEWAY#
Nov 15 18:23:26.607: PIM(0): Received v2 Register on GigabitEthernet0/0 from 172.20.19.249
Nov 15 18:23:26.607: (Data-header) for 172.20.16.201, group 239.255.255.250
Nov 15 18:23:26.607: PIM(0): Send v2 Register-Stop to 172.20.19.249 for 172.20.16.201, group 239.255.255.250
Nov 15 18:23:26.623: PIM(0): Insert (172.20.16.201,239.255.255.250) join in nbr 172.20.19.249's queue
Nov 15 18:23:26.623: PIM(0): Building Join/Prune packet for nbr 172.20.19.249
Nov 15 18:23:26.623: PIM(0): Adding v2 (172.20.16.201/32, 239.255.255.250), S-bit Join
Nov 15 18:23:26.623: PIM(0): Send v2 join/prune to 172.20.19.249 (GigabitEthernet0/0)
11-15-2020 10:28 AM
config this command under Hub only.
ip pim nbma-mode
11-15-2020 12:43 PM
I added it to the tunnel interface, here's some output from deb pim on HQ/HUB:
Nov 15 20:40:07.615: PIM(0): Received v2 Register on GigabitEthernet0/0 from 172.20.19.249
Nov 15 20:40:07.615: for 172.20.16.201, group 239.255.255.250
Nov 15 20:40:07.683: PIM(0): Insert (172.20.16.201,239.255.255.250) join in nbr 172.20.19.249's queue
Nov 15 20:40:07.683: PIM(0): Building Join/Prune packet for nbr 172.20.19.249
Nov 15 20:40:07.683: PIM(0): Adding v2 (172.20.16.201/32, 239.255.255.250), S-bit Join
Nov 15 20:40:07.683: PIM(0): Send v2 join/prune to 172.20.19.249 (GigabitEthernet0/0)
CARM-GATEWAY(config-if)#
Nov 15 20:40:10.483: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.255.255.250
Nov 15 20:40:12.795: %FW-6-DROP_PKT: Dropping tcp session 13.66.5.76:50624 199.27.251.53:22 on zone-pair ZP_INTERNET-TO-SELF class class-default due to DROP action found in policy-map with ip ident 59217
Nov 15 20:40:20.175: PIM(0): Received v2 Join/Prune on GigabitEthernet0/0 from 172.20.19.249, to us
Nov 15 20:40:20.175: PIM(0): Join-list: (*, 239.255.255.250), RPT-bit set, WC-bit set, S-bit set
Nov 15 20:40:20.175: PIM(0): Update GigabitEthernet0/0/172.20.19.249 to (*, 239.255.255.250), Forward state, by PIM *G Join
Nov 15 20:40:20.175: PIM(0): Prune-list: (172.20.16.131/32, 239.255.255.250) RPT-bit set
Nov 15 20:40:20.175: PIM(0): Prune-list: (172.20.16.201/32, 239.255.255.250) RPT-bit set
Nov 15 20:40:27.479: PIM(0): Received v2 Join/Prune on Tunnel0 from 172.20.254.4, to us
Nov 15 20:40:27.479: PIM(0): Join-list: (*, 239.255.255.250), RPT-bit set, WC-bit set, S-bit set
Nov 15 20:40:27.479: PIM(0): Update Tunnel0/172.20.254.4 to (*, 239.255.255.250), Forward state, by PIM *G Join
Nov 15 20:40:27.479: PIM(0): Update Tunnel0/172.20.254.4 to (172.20.16.201, 239.255.255.250), Forward state, by PIM *G Join
In the end, this is still the mroute table for the referenced branch 2 :
(*, 239.255.255.250), 02:02:59/stopped, RP 172.20.19.246, flags: SJCL
GigabitEthernet0/0, Forward/Sparse-Dense, 01:56:31/00:02:30
(172.20.32.32, 239.255.255.250), 00:00:16/00:02:43, flags: LJT
GigabitEthernet0/0, Forward/Sparse-Dense, 00:00:16/00:02:43
(172.20.32.37, 239.255.255.250), 00:00:19/00:02:40, flags: LJT
GigabitEthernet0/0, Forward/Sparse-Dense, 00:00:19/00:02:40
(172.20.42.5, 239.255.255.250), 00:00:20/00:02:39, flags: LJT
GigabitEthernet0/0, Forward/Sparse-Dense, 00:00:20/00:02:39
It annoys me that the two branches seems to be sharing multicast, but not the stream from the HQ/HUB
11-16-2020 11:59 PM - edited 11-17-2020 06:33 AM
I have a feeling that the ZBF might be the culprit.
Did you configure the spoke tunnels with 'ip pim dr-priority 0' ?
11-17-2020 06:25 AM
HUB
ip nhrp nhs multicast dynamic
ip pim nbma-mode
this dual need in Hub to make multicast work.
11-17-2020 07:19 PM
Hello
As your using sparse-dense mode remove the following and test again
ip pim bidir-enable
