IPSEC NAT-T with IKEv1 not working?
EM_Chris
Hello guys, I'm trying to set up a basic site-to-site lab with NAT-T using port 4500 but I'm not sure if I'm missing a config or something needs to be removed somewhere on one of the routers or if I'm doing something wrong in general.
The loopbacks are acting as the interesting traffic LAN subnets to be encrypted and decrypted but when I ping 10.2.2.2 sourced from 10.1.1.1 on R1 I am seeing phase 1 up but phase 2 is showing send errors
R1#show crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst src state conn-id status
192.168.1.2 192.168.2.2 QM_IDLE 1004 ACTIVE
IPv6 Crypto ISAKMP SA
R1#show crypto ipsec sa
interface: FastEthernet0/0
Crypto map tag: crypto_map_test, local addr 192.168.1.2
protected vrf: (none)
local ident (addr/mask/prot/port): (10.1.1.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (10.2.2.0/255.255.255.0/0/0)
current_peer 192.168.2.2 port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 115, #recv errors 0
local crypto endpt.: 192.168.1.2, remote crypto endpt.: 192.168.2.2
path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet0/0
current outbound spi: 0x0(0)
PFS (Y/N): N, DH group: none
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
R1#
On R2 I'm seeing this
R2# show crypto isakmp sa
192.168.2.2 192.168.2.1 QM_IDLE 1004 ACTIVE
R2#
Any answers or suggestions in helping me correct and understand the NAT-T functioning is greatly appreciated
Here are the configs below.
R1#sh run
Building configuration...
Current configuration : 2415 bytes
upgrade fpd auto
version 12.4
hostname R1
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
crypto keyring crypto_keyring_test
local-address 192.168.1.2
pre-shared-key address 192.168.2.2 key cisco
crypto isakmp policy 100
encr aes 256
authentication pre-share
group 14
crypto isakmp policy 200
encr aes 256
group 5
lifetime 28800
crypto isakmp policy 300
encr aes 256
group 2
lifetime 28800
crypto isakmp policy 400
encr aes 256
group 5
lifetime 28800
crypto isakmp policy 500
encr aes 256
group 2
lifetime 28800
crypto isakmp policy 600
encr aes
group 2
crypto isakmp policy 700
encr aes
group 2
lifetime 36600
crypto isakmp keepalive 10 10
crypto isakmp profile crypto_profile_test
description test crypto profile
self-identity address
match identity address 192.168.2.2 255.255.255.255
crypto ipsec transform-set transform_set_test esp-aes 256 esp-sha-hmac
crypto map crypto_map_test 1 ipsec-isakmp
description test crypto map
set peer 192.168.2.2
set transform-set transform_set_test
set reverse-route tag 100
set isakmp-profile crypto_profile_test
match address crypto_acl_test
reverse-route static
ip tcp synwait-time 5
interface Loopback0
ip address 10.1.1.1 255.0.0.0
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.0
duplex half
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip http server
no ip http secure-server
ip access-list extended crypto_acl_test
permit ip 10.1.1.0 0.0.0.255 10.2.2.0 0.0.0.255
no cdp log mismatch duplex
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R1#
NAT#sh run
Current configuration : 1799 bytes
! Last configuration change at 03:09:24 UTC Wed Nov 18 2020
version 16.7
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
platform console serial
hostname NAT
boot-start-marker
boot-end-marker
no aaa new-model
subscriber templating
license udi pid CSR1000V sn 997IXWXAFGO
no license smart enable
diagnostic bootup level minimal
redundancy
interface GigabitEthernet1
ip nat inside
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet2
ip address 192.168.2.1 255.255.255.0
ip nat outside
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet3
no ip address
shutdown
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet4
no ip address
shutdown
negotiation auto
no mop enabled
no mop sysid
ip nat inside source static udp 192.168.1.2 500 192.168.2.1 500 extendable
ip nat inside source static udp 192.168.1.2 4500 192.168.2.1 4500 extendable
ip nat inside source list PAT interface GigabitEthernet2 overload
ip http server
ip http authentication local
ip route 0.0.0.0 0.0.0.0 192.168.2.2
ip route 10.1.0.0 255.255.0.0 192.168.1.2
ip access-list extended PAT
permit ip 192.168.1.0 0.0.0.255 any
permit ip 10.1.0.0 0.0.255.255 any
control-plane
line con 0
stopbits 1
line vty 0 4
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
NAT#
R2#sh run
upgrade fpd auto
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
local-address 192.168.2.2
pre-shared-key address 192.168.2.1 key cisco
encr aes 256
group 14
encr aes 256
group 5
lifetime 28800
encr aes 256
group 2
lifetime 28800
encr aes 256
group 5
lifetime 28800
encr aes 256
group 2
lifetime 28800
encr aes
group 2
encr aes
group 2
lifetime 36600
match identity address 192.168.2.1 255.255.255.255
set peer 192.168.2.1
interface Loopback0
ip address 10.2.2.2 255.0.0.0
ip address 192.168.2.2 255.255.255.0
duplex half
ip route 0.0.0.0 0.0.0.0 192.168.2.1
no ip http server
permit ip 10.2.2.0 0.0.0.255 10.1.1.0 0.0.0.255
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2#
0 Replies 0
