Bridge Config IOS XE 17.6
hope someone can help figure this out.
We've got a configuration that works fine for remote sites where we've got IOS Routers. We're going to start replacing them by ISR running ISO XE 17.6 or above.
I can't find a way to configure the following to the ISR
I know protocal IEEE isn't supported anymore and the ISR uses BDI instead.
The part I'm stuck is how to associate the bridge-domain to the ATM interface.
The interfaces don't have bridge-domain under them to associate to it.
This is the config for an IOS Router
bridge irb
! bridge 1 protocol ieee bridge 1 route ip ! interface ATM0 no ip address load-interval 30 no atm ilmi-keepalive no shut ! interface ATM0.835 point-to-point bridge-group 1 bridge-group 1 spanning-disabled pvc 8/35 bridge-dot1q encap 10 encapsulation aal5snap ! interface BVI1 ip address X.X.X.X ip mtu 1492 ip tcp adjust-mss 1452
I appreciate it if anyone has a clue how I can get it sorted.
M02@rt37
Hello @william85ribeiro,
Interface BDI1 is used as the Bridge Domain Interface and is associated with the bridge group 1.
bridge irb
interface BDI1
ip address X.X.X.X 255.255.255.0
ip mtu 1492
bridge 1 route ip
interface ATM0
no ip address
load-interval 30
no shut
pvc 8/35
bridge-group 1
Best regards
Hi M02@rt37
Unfortunately... that's where my problem is. The IOS XE 17.6 doesn't have any bridge command under the interface.
See the attachment.
Device info:
C1117 - IOS XE 17.06.05 with ipbasek9, securityk9, and appxk9
Thanks.
PolyCaleb
try using service instance (which doesn't work on subinterfaces) so I'm not sure how it will work with the ATM0.835 (I've never used ATM interfaces).
interface ATM0
 service instance 1 ethernet
  encapsulation dot1q 10
  bridge-domain 1
I used the service instance to set up the bridging on ISR4331 and C8200 routers running IOS 17.6
