Bridged connection - no DHCP or UDP traffic
nsimkins
We have a small remote location a block away from our main building connected via bridged T1.  Here's the flow:
Main Building >> 2801 >> T1 << 2801 << Remote Building
This is currently operating as a bridged connection between the two locations.  We are having a problem with DHCP requests not working at the Remote Building as well as specific UDP(port 7700) traffic.  I tried working with ip-forward protocol commands but that didn't appear to help.
Is there any solution available to help in this situation - allow DHCP traffic and UDP traffic to flow between locations?
Here's the Remote Building config:
version 12.4
hostname Remote
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip routing
no ip cef
interface FastEthernet0/0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface FastEthernet0/1
ip address 10.8.12.213 255.255.255.0
no ip route-cache
duplex auto
speed auto
interface Serial0/1/0
no ip address
encapsulation ppp
no ip route-cache
service-module t1 timeslots 1-24
bridge-group 1
ip classless
ip forward-protocol spanning-tree
ip forward-protocol turbo-flood
ip forward-protocol udp 7700
ip http server
no ip http secure-server
control-plane
bridge 1 protocol ieee
line con 0
line aux 0
line vty 0 4
privilege level 15
login
end
Here's the Main Building 2801 config:
version 12.3
hostname Main
boot-start-marker
boot-end-marker
no mmi pvc
no aaa new-model
ip subnet-zero
no ip routing
no ip cef
no ftp-server write-enable
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
ip address 10.8.12.214 255.255.255.0
no ip route-cache
duplex auto
speed auto
no ip address
encapsulation ppp
no ip route-cache
service-module t1 clock source internal
bridge-group 1
ip classless
ip http server
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Richard Burts
Nick
The ip forward-protocol is used only with IP forwarding of traffic. And since you have configured no ip routing on both routers the ip forward-protocol statements you have configured are not doing any good and just complicate the configuration. I suggest that you remove them to clean up the config.
Is there a reason why you have not configured bridge-group 1 on the Ethernet interfaces that are configured with IP addresses? I suggest that you put bridge-group on these interfaces.
What is providing DHCP and how is it connected?
Rick
Rick
