Bridging async interface
spennaertz
I have a C1841 with 2 WICs installed (BRI and a analogue modem/async). My goal is to put both the BRI and async interfaces into bridging mode. With the BRI interfaces this is no problem but with the async interfaces it apperently not possible (also not when I created dialer interfaces).
Has anyone a suggestion or knows a workaround?
Curious I am because I was unable to find any solution for this...
Thx Sander
s.jankowski
Level 4
Level 4
Refer to the document which gives a sample ISDN bridging configuration.
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_configuration_example09186a008014bad2.shtml
