bridging question, g.shdsl connection
ssmaling
I'm trying to connect two switches with a g.shdsl connection:
switch--Cisco828---<line>---Cisco828--switch
This setup should replace an unstable LRE link.
The 828 routers are each connected to a switch with the ports set in trunking mode. The config below works
fine for VLAN1 traffic, however all other VLANs are not bridged.
bridge irb
interface Ethernet0
no ip address
bridge-group 1
interface ATM0
no ip address
no atm ilmi-keepalive
dsl equipment-type CO ! set to CPE on the other side
dsl operating-mode GSHDSL symmetric annex B
dsl linerate AUTO
interface ATM0.1 point-to-point
bridge-group 1
pvc 0/35
encapsulation aal5snap
interface BVI1
ip address 172.25.8.14 255.255.255.0
bridge 1 protocol ieee
bridge 1 route ip
So my initial idea was to use dot1Q trunking and create subinterfaces with additional bridge groups for the VLANs required:
interface Ethernet 0.1
encapsulation dot1Q 1
bridge-group 1
interface Ethernet 0.2
encapsulation dot1Q 2
bridge-group 2
bridge-group 1
pvc 0/35
interface ATM0.2 point-to-point
bridge-group 2
pvc 0/36
bridge 1 route ip
bridge 2 protocol ieee
But....the 828 does not support dot1Q encapsulation on the ethernet port. Anyone has an idea on how to solve this? A layer 2 connection is required for the security gateway (security is based on mac addresses).
0 Replies 0
