Cisco 851 Router, WLAN configuration
voytechp420
Hello everyone,
I purchased a Cisco router 851 with intergrated wireless AP. I was able to configure the LAN but I can't get the WLAN to work. I was googling for it all over the place, I did a lot of configs that cisco.com has and still nothing. I have 2 wireless computers running Win XP and they don't detect any WLANs, the WLAN(OK) LED on the router is blinking.
This router has 4 FastEthernet interfaces and one Dot11Radio0, Vlan1 and BVI1, ... here's another question, if I want to set up a LAN and WLAN which interface (Vlan1 or BVI1) should have the ip address?
I configured the router so that Vlan1 has IP address: 10.0.0.1 255.0.0.0 I enabled NAT and DHCP and that works fine (but this is only for LAN configuration)... However in the sample configs for WLAN that I found on cisco, it shows that BVI1 has the IP address and Vlan1 does not... This is how my network looks like (I have the modem from my ISP)
http://i.i.com.com/cnwk.1d/i/tr/downloads/images/cisco_871/cisco_871_a.png
Please help and I apologize for posting such ridiculous questions
8 Replies 8
jackyoung
Level 6
Level 6
It looks like the Router/AP did not broadcast the SSID, can you check it or use some scanner to scan the AP ? e.g. Netsumbler
Did check below doc. and sample ?
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_guide_chapter09186a008045d289.html#wp79536
According to the sample as above, the ip address should be configured at BVI and VLAN will be bridged with the radio interface.
Please post the config and it is easier to troubleshoot the problem.
Hope this helps.
Hello
Thank you for your reply. Here's the config:
version 12.4
no service pad
service password-encryption
hostname cisco
boot-start-marker
boot-end-marker
enable secret 5 $1$w1FR$TQnOIJhFdFukc.dthkgFY1
enable password 7 071D285A4F
no aaa new-model
resource policy
ip subnet-zero
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.1
ip dhcp pool LAN
import all
network 10.0.0.0 255.0.0.0
dns-server xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
default-router 10.0.0.1
lease 10
ip cef
ip name-server 194.xxx.xxx.xxx
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 83.xxx.xxx.xxx 255.xxx.xxx.xxx
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
interface Vlan1
ip address 10.0.0.1 255.0.0.0
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 83.xxx.xxx.xxx
ip http server
ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 permit 10.0.0.0 0.255.255.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
In this config, the Radio interface is disabled. Thank you very much...
Please ignore the previous config.... This is the current configuration that includes WLAN config:
version 12.4
no service pad
hostname cisco
boot-start-marker
boot-end-marker
enable secret xxx
enable password xxx
no aaa new-model
resource policy
ip subnet-zero
ip dhcp pool LAN
import all
dns-server 194.xxx.xxx.xxx 194.xxx.xxx.x
lease 10
ip cef
bridge irb
ip address 83.xx.xxx.xxx 255.255.255.xxx
ip nat outside
duplex auto
speed auto
no cdp enable
no ip address
broadcast-key vlan 1 change 45
encryption vlan 1 mode ciphers tkip
ssid wireless
vlan 1
authentication open
authentication network-eap voytech
authentication key-management wpa
54.0
rts threshold 2312
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no snmp trap link-status
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 83.xx.xxx.xxx
ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
end
I installed the Network Stumber but it does not detect any SSIDs... what can be wrong?
Referring to the link of the sample config. of wireless section, there is no issue on the provided config. I suspect it may be the hardware issue. What is the IOS running on this router ? You may consider to upgrade the IOS and open a tac case w/ Cisco to investigate the radio problem.
For the overall configuration, you can refer to the link that I provided at the bottom, there is a full sample config. w/ both VLAN and BVI are used, VLAN for LAN and BVI for the radio.
Hope this helps.
Thanks for the help, I got it working :)
It is great if it works now. Could you tell what have you done to make it work ? Or what is the problem to make not work ? Many thx. :)
Thanks jack, the config that I posted was totally fine, all I had to do is to add "guest-mode" to the Dot11Radio0 interface in SSID mode...
Thanks again.
Cisco rulez :)
Thx. for the update. Enjoy ~ ;)
