Broadcast domain over internet
Rayn
I would like to find out if it is possible to create one broadcast domain with several IR809 routers (5 in my case) via the mobile network, so that all hosts behind the routers can receive broadcast messages?
The routers are connected via dmvpn.
Thank you very much for your help!
Giuseppe Larosa
Hello @Rayn ,
between two routers you could use L2TPv3 that provides a point to point L2 transport service.
With 5 devices connected via DMVPN  I think it is a problem to create such emulated broadcast domain.
You could use an MPLS service provider service like VPLS and using simple switches as L2 CE devices in this way you would avoid to overload your routers and that service would run in parallel with your DMVPN.
Hope to help
Giuseppe
Hi Giuseppe,
Thank you for your suggestion.
Best regards
