BSTUN Multi-point (ASYNC), where I set the destination address?
panchotait
Hi all!
What I want to do is, transport the serial0 and serial1 from a remote route to a local router at his local serial0 interface.
The routing mechanism is very easy, it like a RS485, incoming data at the local router is trasmited to the remote serial0 and serial1.
If some data income at the serial0 or serial1 at the remote, this data travel to the local an is printed into de local serial0
Remote Serial0 and Serial1 ends at the local Serial0. The local Serial0 starts and ends at the remote Serial0 and Serial1.
Both serials are RS-232 (is a async-protocol group)
The RS-232 protocol is UNADDRESSED
The application is a back-up serial link.
My Config is:
LOCAL R236:
bstun peer-name 192.168.33.236
bstun protocol-group 10 async-generic
interface serial0
     physical-layer async
     encapsulation bstun
     bstun group 10
     bstun route address 20 tcp 192.168.33.237
     bstun route address 21 tcp 192.168.33.237
     asp role secondary
line 1
     speed 9600
     databits 8
     parity none
     stopbits 1
     no flowcontrol
REMOTE R237:
bstun peer-name 192.168.33.237
interface serial0
     encapsulation bstun
     bstun group 10
     bstun route address 20 tcp 192.168.33.236
     asp role primary
interface serial1
     encapsulation bstun
     bstun group 10
     bstun route address 21 tcp 192.168.33.236
     asp role primary
line 1
     speed 9600
     databits 8
     parity none
     stopbits 1
     no flowcontrol
line 2
     speed 9600
     databits 8
     parity none
     stopbits 1
     no flowcontrol
If i debug the BSTUN PACKET:
*Mar  7 02:31:18.182: %BSTUN-3-NOPEER: No peer configured to route frame with destination address 0 (bstun group 10)
At the Cisco IOS Software System Error Messages ARAP Error Messages Manual notes:
[chars] (bstun group [dec])
Explanation A BSTUN route has not been configured for the frame with a destination address.
Recommended Action If this message appears while you are debugging BSTUN, it indicates that no
specific BSTUN route has been configured for the frames being received with the device address
listed in the packet debug trace. You may choose to configure a BSTUN route, or ignore this
message.
I know that the address must be content on the frames that income at the serial port interface, I mean the router fordward the frames if this have some BYTE and the start that indicate what is address of a remote device, so i guess that this routing mechanism use that byte to select the remote router.
But If I set the address at the local and remote route, the router is not who must include his own address in the frame?
If I set a point to point link, the only way if I want to transport more that 1 link,? for now the only way is set TWO groups and set one for first link ant the other for the second. (Serial0--Group1--Serial0 and Serial1--Group2--Serial1)The router do not let me set the same group ant the same route.
So, My question is, where at the Serial interface i set the LOCAL ADDRESS for a BSTUN protocol ¿?
Best Regards
Frank
Conectia Wireless SA
paolo bevilacqua
I don't think you can use BSTUN for non Bisync, non-framed traffic.
Hi Paolo
So at both serials we must set:
  bstun route all tcp 192.168.33.236
Now how the router identify the interfases, I mean how it know what remote serial port go to what remote port.
I mean what peer connect with the other.
The only way that i found is the GROUP ID.
Now If i want to have one serial like master and other two like slaves, those slaves works at the same router.
If I set this:
The second one serials do not let me use the same address at the same group
Serial 0
     bstun group 1
Serial 1
     bstun group 1
At now i'm testing the same but using UDPTN as protocol, allmost that use UDP so it must work, the only thing is that i don't have any dispatch-character so it must transmit each char, I don't know if the dispatch-timeout can be set on 6mSeg (9600 baud timeout)
Best Regards
Frank
Now I'm testing UDPTN as transport method.
I found a little problem.
I must implement a multicast UDP transport, but the autocommand line and the UDPTN mechanism have an issue.
The route who transmit the strem :
LOCAL R236
Serial 0/1
line 2
     autocommand udptn 239.50.0.1 /transmit
REMOTE R237
Serial 0/1
line 2
     autocommand udptn 239.50.0.1 /receive
This works great, but the RS232 port is not a one way line, It must TRANSMIT and RECEIVE. Not only transmit from a local to a remote, both operation must work
So I think set-up to differents Multicast address, one for the transmiters and other for the receivers.
I Must set up the autocommand UDPTN like this:
LOCAL R236
Line 2
     autocommand UDPTN 239.50.0.1 /transmit
     autocommand UDPTN 239.50.0.2 /receive
REMOTE ROUTERS
Line X
     autocommand UDPTN 239.50.0.1 /receive
     autocommand UDPTN 239.50.0.2 /transmit
How i can set-up that autocommand ???
Best Regards
Frank
