bug in 3560 IOS
Frnds please help me with the folowing I am using cisco packet tracer 6.0.1
I am trying to create L3 link aggregation on cisco 3560 MLS.
Here some issue that i am facing while doing the same.
When I am selecting multiple port using int range command I am not getting option channel-group.
Switch(config)#int range f0/1 -3
Switch(config-if-range)#?
  arp          Set arp type (arpa, probe, snap) or timeout
  bandwidth    Set bandwidth informational parameter
  cdp          CDP interface subcommands
  delay        Specify interface throughput delay
  description  Interface specific description
  duplex       Configure duplex operation.
  exit         Exit from interface configuration mode
  ip           Interface Internet Protocol config commands
  mdix         Set Media Dependent Interface with Crossover
  no           Negate a command or set its defaults
  power        Power configuration
  shutdown     Shutdown the selected interface
  speed        Configure speed operation.
  standby      HSRP interface configuration commands
  switchport   Set switching mode characteristics
However when I am selecting individual interface then i am getting the option channel-group or channel-protocol
Switch(config)#int f0/1
Switch(config-if)#?
  channel-group      Etherchannel/port bundling configuration
  channel-protocol   Select the channel protocol (LACP, PAgP)
  hold-queue         Set hold queue depth
  mls                mls interface commands
  service-policy     Configure QoS Service Policy
  tx-ring-limit      Configure PA level transmit ring limit
Also after creating the port channel (ofcourse by running command on individual interfaces)
I am not able to assign ip address on port-channel interface(already all the child link are l3)
Switch(config)#int port-channel 1
Switch(config-if)#?
  cdp               Global CDP configuration subcommands
  spanning-tree     Spanning Tree Subsystem
  storm-control     storm configuration
Switch(config-if)#
Please let me know if this is bug in 3560 as I am not able to assign ip on port-channel interface and channel-protocol command not working on int range interface.
Peter Paluch
Regarding the lack of the "channel-group" command in the "interface range" context, this is a bug - but this is a bug of Packet Tracer, not a bug of 3560 because there is in fact no 3560 at all. Packet Tracer only gives off an impression it has a Catalyst 3560 inside but in reality, there is no 3560 IOS running inside the Packet Tracer. It only approximates its behavior and features.
Regarding the lack of "ip address" command - I am not sure whether Packet Tracer supports it at all. But if it does then you must first convert the physical ports into routed ports using the "no switchport" command, and only then you can bundle them into an EtherChannel and optionally assign an IP address to it. An EtherChannel can only be created as switched (when bundling switchports) or routed (when bundling ports configured as "no switchport") and cannot be converted between these types after it has been created. To change its type, you first need to remove it, configure the physical ports to the intended mode (switched or routed) and then recreate the EtherChannel.
Best regards,
Peter
