Build-in variable for cli events in EEM
mario.jost
Level 3
Level 3
If i create an event manager applet to capture logs, i can work with a variable called $_syslog_msg. Example:
event manager applet RUNATEVERYLOG
event syslog pattern "Configured programmatically" maxrun 4
action 1.0 cli command "enable"
action 2.0 puts "we will send the log $_syslog_msg"
 So i can work with the full log entry and not just the part that was responsible for triggering the event manager applet. I am looking for a way to do the same with cli events. So basically i have this:
event manager applet FILTERCMD
  event cli pattern "^interface GigabitEthernet1/0/[0-9]+$" sync yes
  action 001 cli command "enable"
  action 002 cli command "tclsh flash:/filtercmd.tcl $_cli_cmd"
I used a placeholder variable called $_cli_cmd. This does not actually work, but should bring out the point of what i am actually trying to achieve. So basically, i am looking for the correct variable for $_cli_cmd.
Does anyone have this? i couldnt find anything in the EEM documentation from Cisco.
Dan Frey
INTERNET#show event manager detector cli detailed | b Applet
	Applet Configuration Syntax:
	[ no ] event [tag <tag-val>] cli
		 pattern <pattern-val>
		 [enter] [questionmark] [tab]
 		 sync {yes | no}
		 skip {yes | no}
		 verifyprc {yes | no}
		 [occurs <occurs-val>]
		 [period <sec.msec>]
		 [default <sec.msec>]
		 [mode <parser mode val>]
		 [maxrun <sec.msec>]
		 [ratelimit <sec.msec>]
	Applet Built-in Environment Variables:
	$_event_id
	$_job_id
	$_event_type
	$_event_type_string
	$_event_pub_time
	$_event_pub_sec
	$_event_pub_msec
	$_event_severity
        $_cli_msg
	$_cli_msg_count
	$_cli_line
	$_cli_key
	$_cli_tty
	$_cli_username
	$_cli_host
	$_cli_privilege
	$_cli_error_code
	$_cli_mode_context
INTERNET#
balaji.bandi
Not sure what is the use case here can you explain more about syslog pattern and eventually you sending logs to syslog.
why not configure syslog send logs to syslog server, rather use EEM
or am i missing the view you looking to achieve ?
BB
Dan Frey
 		 sync {yes | no}
		 skip {yes | no}
		 [period <sec.msec>]
		 [maxrun <sec.msec>]
	$_event_id
	$_job_id
	$_event_type
	$_event_type_string
	$_event_pub_time
	$_event_pub_sec
	$_event_pub_msec
	$_event_severity
        $_cli_msg
	$_cli_msg_count
	$_cli_line
	$_cli_key
	$_cli_tty
	$_cli_username
	$_cli_host
	$_cli_privilege
	$_cli_error_code
	$_cli_mode_context
INTERNET#
Thank you very much Dan, you just saved my day. Not only did you post the correct name of the variable (darn i was so close) but you also showed the command with which we can get all possible variables from certain eem applets. I just tested this and it works. Great job m8.
