After changing PPPOE max session , IPTV not connecting automatically A
saahiprahi
16 Replies 16
Use threshold keyword
Abd see if routet generate any log for high session numbers
MHM
what is the command to set threshold
sessions max limit number-of-sessions [threshold threshold-value]
MHM
since we both suspect that this issue of session limit reach so
what make session keep count ?
I think you missing keepalive under PPP
keepalive 60 20
MHM
we set keepalive 12 under ppp is that ok or can i change it to keepalive 60 20
change it to 60 20 and monitor
MHM
changed to 60 20 still issue is there. can i share you video for your reference
sessions max limit number-of-sessions this command is not accepting in ASR 1001-X
have you tried to clear all PPPOE sessions ? I think the command is:
clear pppoe all
we tried clear pppoe all ( session disconnected and reconnected) but still issue is there
hi
debug pppoe packet
debug ppp negotiation
share both if you can
in end do
undebug all
MHM
please find the details
ASR2#debug pppoe packets
PPPoE control packets debugging is on
ASR2#debug
ASR2#debug ppp negotiation
PPP protocol negotiation debugging is on
ASR2#undebug
ASR2#undebug all
All possible debugging has been turned off
can i share my screen ?
