Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
I have four 3120's in an HP blade system that are currently configured as 4 standalones. I want to stack them. is it as easy as configuring the first one as switch 1 and then connecting the stackwise cables? Will I need to reboot anything?
Before you connect the switch modules in a stack, keep in mind these stacking guidelines. You should install the stack master switch module and run the initial setup program on that switch module before you connect the StackWise Plus cables to other stack members
