Bundling/Link Aggregation on a Cisco Router with more than 1 E1/T1 link
r20039r20039
Hi Experts
Is it possible to bundle more than one E1/T1 module on a single router and bundle their bandwidth and send that to another router/switch?
If yes, How? What does this process is named on books, and in the industry?
Mark Malone
you can bundle links like that with multilink feature MLP
obviously both ends need to support it
http://www.cisco.com/c/en/us/td/docs/ios/qos/configuration/guide/15_1/qos_15_1_book/mlppp_over_serial.html
http://www.cisco.com/c/en/us/td/docs/routers/10000/10008/configuration/guides/broadband/bba/mlp.html
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As Mark documents, MLPPP is often used to bundle E1/T1 interfaces.
Between routers, though, you can often route across multiple interfaces concurrently.  Many routing protocols, by default, will use equal cost links.  This technique has advantages and disadvantages over MLPPP.
Some hardware, such as ATM E1/T1 interfaces, often supports inverse mux, another method to bundle multiple links.
If you're working with Ethernet interfaces, some form of port channeling might be supported too.
