bundling T3
jobbykjose
can we bundle T3 links with multilink interface. if possible, which basic router model support that. can anyone help on this.
Edison Ortiz
Jobby,
You can bundle T3 links with MLPPP and any router supports it.
Please read this URL
http://www.cisco.com/warp/public/131/mppp-ddr.html
Keep in mind, MLPPP needs to be configured at both ends of the connection.
___
Please rate helpful posts.
AFAIK, you need a Shared Port Adapter (SPA) in order to support MLPPP. The SPA is available on the high-end platforms such as the 7600 and the 12000 series.
Check this link as well:
Cisco 2-Port and 4-Port Channelized T3 (DS0) Shared Port Adapters
http://www.cisco.com/en/US/products/ps6267/products_data_sheet0900aecd8027cb3f.html
GNT
devang_etcom
Level 7
Level 7
look at this:
http://www.cisco.com/univercd/cc/td/doc/product/aggr/10000/10ksw/mlppos.htm
rate this post if it helps
regards
Devang
