Bus error due to which router get Rebooted
Manish Prasad
Level 5
Level 5
Hello Netpros,
Need a help to solve out one problem regarding the Bus error in 7206VXR due to which router got rebooted.
Error Log
System returned to ROM by bus error at PC 0x32313300, address 0x0 at 03:42:22 GMT Thu Oct 22 2009
System restarted at 03:45:31 GMT Thu Oct 22 2009
Cisco 7206VXR (NPE-G1) processor (revision C) with 491520K/32768K bytes of memory.
Is it required to upgrade the IOS to solve this issue?
Thanks in Advance.
Manish Prasad
5 Replies 5
Giuseppe Larosa
Hello Manish,
the bus error can be the sign of a SW bug or a real bus error case that occurred on your device.
Only in first case an IOS upgrade may help.
To understand what is your case you should post
sh ver
sh stack
into error message decoder tool or here in the forum as attachment files.
see
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800cdd51.shtml
Hope to help
Giuseppe
As required the details are attached.
Router_12#sh ver
Cisco IOS Software, 7200 Software (C7200-ADVENTERPRISEK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 10-Oct-08 10:10 by prod_rel_team
ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200-KBOOT-M), Version 12.4(12), RELEASE SOFTWARE (fc1)
SP_Union_2 uptime is 6 hours, 9 minutes
System image file is "disk2:c7200-adventerprisek9-mz.124-22.T.bin"
Processor board ID 36402628
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.11
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 300 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
62720K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Router_12#sh stack
Minimum process stacks:
Free/Size Name
5440/6000 Inspect Init Msg
59204/60000 script background loader
58920/60000 EEM Auto Registration Proc
5440/6000 SASL MAIN
2436/3000 allegro libretto init
10576/12000 Router Init
4216/6000 Update prst
3380/12000 Init
4244/6000 DIB error message
5228/6000 RADIUS INITCONFIG
10176/12000 Exec
2288/3000 Rom Random Update Process
11360/12000 IPRM
5356/6000 URPF stats
6288/12000 SSH Process
Interrupt level stacks:
Level Called Unused/Size Name
1 3446810 6748/9000 Network interfaces
2 0 9000/9000 DMA/Timer Interrupt
3 193 7788/9000 PA Management Int Handler
4 6234 8596/9000 Console Uart
5 0 9000/9000 OIR/Error Interrupt
7 5548643 8572/9000 NMI Interrupt Handler
System was restarted by bus error at PC 0x32313300, address 0x0 at 03:42:22 GMT Thu Oct 22 2009
Image text-base: 0x600089D4, data-base: 0x63B9C320
Stack trace from system failure:
FP: 0x67FDAED8, RA: 0x32313300
Thanks You
Manish
Hello Manish,
the feedback from output interpreter is:
ERROR: This router was last restarted by a bus error:
'bus error at PC 0x32313300, address 0x0 at 03:42:22 GMT Thu Oct 22 2009'
The system encounters a bus error when the processor tries to access a memory location
that either does not exist (a software error) or does not respond properly (a hardware
problem).
TRY THIS: Issue a 'show region' and check if the address location (the 'address'
part of the bus error - 0x0) falls within an existing address range. If the address
reported by the bus error does not fall within the ranges displayed in the 'show
region' output, this means that the router was trying to access an invalid address.
This indicates that it is a Cisco IOS Software problem. Paste the output from the
'show stacks' command to decode the output and identify the Cisco IOS Software
bug that is causing the bus error. If the address falls within one of the ranges
in the 'show region' output, it means that the router was accessing a valid memory
address, but the hardware corresponding to that address is not responding properly.
This indicates a hardware problem. Try reseating the hardware belonging to this
address range before attempting to replace it. Use the Troubleshooting Bus Error
Crashes document for additional assistance.
so may you post a sh region
But it is likely to be a SW error because address is 0x0
Hope to help
Giuseppe
Show region command is not running on this IOS.
By the way thank you for your help.
Prasad
How to identify like in which sh region output the bus error address is lying....
Suppose  Bus error address is 0x000BB4C4 and show region output as follows:
  Start         End     Size(b)  Class  Media  Name
0x00000000  0x007FFFFF     8388608  Local  R/W    main
0x00001000  0x0001922F       98864  IData  R/W    main:data
0x00019230  0x000666B3      316548  IBss   R/W    main:bss
0x000666B4  0x007FEFFF     7965004  Local  R/W    main:heap
0x007FF000  0x007FFFFF        4096  Local  R/W    main:flhlog
0x00800000  0x009FFFFF     2097152  Iomem  R/W    iomem
0x03000000  0x037FFFFF     8388608  Flash  R/O    flash
0x0304033C  0x037A7D3F     7764484  IText  R/O    flash:text
So, where the bus error address is lying and how we can identify. As per me , it should be in
