Business class routers having 70% less bandwidth than cheap $5 router.
kingcastro82
I have the following network. (IMAGE ATTACHED)
When using a $5 wrt120n router from a junk draw in my closet, I get 40mb/20mb and I can reach my web server using FQDNs from my lan(inside my house).
When using either a 1841 or 2811(same problem on both), I get 13mb/23mb and I can't reach my web server from my lan.
I have spent two weeks working on this problem with no luck and at this point I don't get what makes a business class blade server better than a $5 old junk router? Can someone help me please?
Router Setup minus the line con and vty lines
! Last configuration change at 15:17:09 UTC Fri Dec 29 2017
version 15.1
hostname SERVER_ROUTER
boot-start-marker
boot-end-marker
enable password A$$tA$tic
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp pool name INTERNAL
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
ip domain name HOMENETWORK
no ipv6 cef
voice-card 0
license udi pid CISCO2811 sn FTX1204A3KB
username kingcastro82 password 0 A$$tA$tic
redundancy
interface FastEthernet0/0
ip address dhcp
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.0.0.1
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
interface Serial0/1/0
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list LIST interface FastEthernet0/0 overload
ip nat inside source static tcp 10.0.0.2 80 XX.XXX.XXX.XXX 80 extendable
ip access-list standard LIST
permit 10.0.0.0 0.0.0.255
control-plane
mgcp profile default
scheduler allocate 20000 1000
end
I don't see the default route in your router:
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 dhcp
Also, exclude the default router IP address from the pool:
ip dhcp excluded-address 10.0.0.1
Your DHCP pool does not assign DNS servers, try and add those:
dns-server 8.8.8.8 8.8.4.4
Which IP address do you use in your static NAT statement ? Since your WAN interface gets a DHCP assigned address, you would not know the address, so a static NAT statement is basically not possible without a static public IP address...
Joseph W. Doherty
". . . I don't get what makes a business class blade server better than a $5 old junk router?"
It depends on what you consider "better".
What often makes a Cisco router "better" are features that they can support.
For raw performance, less expensive non-Cisco routers, may indeed, be "better".
