Buying CCNP Switches
waleedothman
Is buying 2 WS-C3550-24-EMI enough for the ccnp switch 642-813 (+GNS3)???????? (real switches can be connected to GNS3 right ?)
Or one should buy different switches,and where to get the best prices and available shipments to Beirut, Lebanon??
8 Replies 8
cadet alain
To experiment more things I would take 3 like this and yes you can connect them to gns3.
Ebay seems a good option to buy from states I guess because I'm living in europe and I bought my switches on ebay from austria at a very good price
but I saw some good prices from USA also.
Regards.
Alain.
Hi Alian,
I was also told that i must be using 3 WS-C3550-24-EMI for most labs??
May I ask what was the price of the 3 switches?
Yes, 3 is better for  e.g spanning-tree and on ebay  3550 -24 fastethernet  with EMI are around 250-350 $.
Regards.
Alain.
ahmed.jama
Hi Walid,
Any reason why you are not using the EtherSwitch module (NM-16ESW) on GNS3 as opposed to buying an actual switch for the exam?
AJ
the NM-16ESW lacks a lot of features like: no dtp, no ISL, no port-security, only CSTP,limited QoS, etc.
Regards.
Alain.
To Ahmad these are the missing features in GNS3
http://www.gns3.net/phpBB/topic229.html?sid=0fd75b0c27e12b3da31432be967ba464
To Alain,
Having multiple NICs on my PC (2.4 GHz dual core , 4 GB RAM) with the 3 switches will do the trick? Or are there any other problems to overcome?
Will I be able to perform all the 642-813 labs?? Will I be able to connect my routers to the switch clouds?
Yes it will.
take a look at this forum for linking real switches to dynamips.
http://7200emu.hacki.at/
Regards.
Alain.
I love 3550 switches, They are old but they were a revolution at the time.
I strongly suggest them for your tests and labs.
http://www.alivetrading.com/s~q-cisco-3550.aspx
