BVI configuration on ASR1002 router
Danne1985
Hi Guys,
We have a cisco7206 router which is going to be replaced with an ASR1002 router. The 7206 has some interfaces in a BVI-group - the config of which i am trying to translate over into IOS XE (which runs on the ASR1002).
Basically i have the following config:
bridge irb
bridge 120 protocol ieee
bridge 120 route ip
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
media-type rj45
no negotiation auto
interface GigabitEthernet0/2.120
encapsulation dot1Q 120
no ip redirects
no ip unreachables
no ip proxy-arp
bridge-group 120
interface GigabitEthernet0/2.3999
encapsulation dot1Q 3999
ip address 10.10.10.10 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip authentication mode eigrp 77 md5
ip authentication key-chain eigrp 77 XXXX
delay 1005
interface BVI120
ip address 172.10.10.10 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
which i am trying to find the equivalent config of, on IOS XE. The nearest answer i could find is posted here:
https://supportforums.cisco.com/thread/2162439
however this seems to work fine for physical interfaces but not for logical subinterfaces which is what i have.
FYI the 7206 is running c7200-advsecurityk9-mz.124-9.T7.bin, and the ASR1002 is running asr1000rp1-adventerprisek9.03.04.02.S.151-3.S2.bin.
Any information anyone can provide on how to translate this config from IOS to IOS XE would be much appreciated. Thanks in advance
Giuseppe Larosa
Hello Danne,
the BDI concept is not limited to physical interfaces, but it uses the concept of Ethernet Virtual Connect as specified in Metro Ethernet forum
see the links below
http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/bdi_ps9343_TSD_Products_Configuration_Guide.html#wp1146536
and
http://www.cisco.com/en/US/docs/ios-xml/ios/cether/configuration/xe-3s/asr1000/ce-ether-vc-infra-xe.html#GUID-A28FC966-6ABD-44D1-9AB6-DD0DDFC2C452
the difference should be
interface Gig0/1
   service instance 1 ethernet
     encapsulation dot1q 120
     bridge-domain 1
interface Gig0/2
     bridge-domain 1
interface BDI1
   ip address x.x.x.x
to be noted you can assign an encapsulation dot1q also to the BDI interface as explained in the first link.
Hope to help
Giuseppe
Thanks for the reply Giuseppe.
So are you saying that Gi0/2 that is configured like this on the 7206 router:
no ip address
duplex auto
speed auto
media-type rj45
no negotiation auto
no ip redirects
no ip unreachables
no ip proxy-arp
bridge-group 120
no ip redirects
no ip unreachables
no ip proxy-arp
delay 1005
interface BVI120
no ip redirects
no ip unreachables
no ip proxy-arp
...can now be configured like this on the ASR?
no ip address
speed 1000
no negotiation auto
  bridge-domain 120
no ip redirects
no ip unreachables
no ip proxy-arp
delay 1005
interface BDI120
no ip redirects
no ip unreachables
no ip proxy-arp
and i would configure Gi0/3 (which is the second interface in the bridge-domain) on the ASR similarly?
I tried creating a service instance under a subinterface but it doesnt seem to work, so this is the only way i can think of doing it that might.
Hi Danne,
Did your configuration work for you on the ASR?
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
We're you able to get this working with the sub-interface?
