07-28-2011 02:24 PM - edited 03-04-2019 01:07 PM
I want to start by noting that I am thoroughly confused at this point and cannot figure out where I am going wrong.
Have been struggling with a connectivity issue following a recent power surge from a storm. A BVI from Cisco Catalyst 3600 cannot communicate with our local network.
We have several satellite connections which connect to us via ADSL. From these satellite offices I can talk to the Cisco 3600 we have here at our central office (BVI 10.60.112.1). There is a connection from the ATM port on the Cisco 3600 which goes to an ATM port on a Cisco Catalyst 8510 and there is an Ethernet connection from that 8510 to the core switch on our local network (Catalyst 6509).
Since I can talk to the 3600 without issue, I believe that the issue is the 8510 config.
Any assistance that anyone can provided would mean the world to me -- I figured this is the best place for a "second set of eyes".
There are only two ports in use on the 8510.
There is activity on both ports of the 8510, but from the local network I cannot see 10.60.112.1 and from the 3600 I cannot see the core.
The 8510 config looks pretty default, like some things were "lost" during the surge (we had backups of the 3600 and not the 8510).
The config goes as follows for the 8500:
version 12.1
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname 8500
username all
sdm ipqos zero
sdm policy 0
ip subnet-zero
atm address 47.0091.8100.0000.0004.dd25.a201.0004.dd25.a201.00
atm router pnni
no aesa embedded-number left-justified
node 1 level 56 lowest
redistribute atm-static
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/1
no ip address
interface ATM0/0/2
no ip address
interface ATM0/0/3
no ip address
interface ATM0/1/0
no ip address
shutdown
lbo short 133
no ima-group
interface ATM0/1/1
no ip address
shutdown
lbo short 133
no ima-group
interface ATM0/1/2
no ip address
shutdown
lbo short 133
no ima-group
interface ATM0/1/3
no ip address
shutdown
lbo short 133
no ima-group
interface ATM0/1/4
no ip address
shutdown
lbo short 133
interface ATM0/1/5
no ip address
shutdown
lbo short 133
no ima-group
interface ATM0/1/6
no ip address
shutdown
lbo short 133
no ima-group
interface ATM0/1/7
no ip address
shutdown
lbo short 133
no ima-group
interface ATM1/0/0
no ip address
sonet ais-shut
sonet threshold sf-ber 4
interface ATM1/1/0
no ip address
sonet ais-shut
interface ATM0
no ip address
interface Ethernet0
no ip address
interface ATM3/0/0
no ip address
sonet ais-shut
interface ATM3/1/0
no ip address
sonet ais-shut
interface ATM4/0/0
no ip address
sonet ais-shut
interface ATM4/1/0
no ip address
sonet ais-shut
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
end
The 3600 config looks like the following:
version 12.2
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname chardsl
logging buffered 10000 debugging
enable secret xxxxxxxxxxx
enable password xxxxxxxx
username all
ip subnet-zero
no ip domain-lookup
call rsvp-sync
cns event-service server
bridge irb
interface ATM0/0
ip address 10.60.120.2 255.255.248.0
atm pvc 1 0 5 qsaal
atm pvc 2 0 16 ilmi
lane config-atm-address 39.840F8001BDE3000014000199.008012341D73.00
lane client ethernet elan8
interface ATM0/0.1 multipoint
shutdown
interface ATM1/0
no ip address
atm vc-per-vp 256
no scrambling-payload
interface ATM1/1
no ip address
atm vc-per-vp 256
interface ATM1/1.1 point-to-point
pvc 1/178
encapsulation aal5snap
bridge-group 1
interface ATM1/1.2 point-to-point
pvc 1/175
bridge-group 1
interface ATM1/1.3 point-to-point
pvc 1/37
bridge-group 1
interface ATM1/1.4 point-to-point
pvc 1/34
bridge-group 1
interface ATM1/1.5 point-to-point
pvc 1/51
bridge-group 1
interface ATM1/1.6 point-to-point
pvc 1/33
bridge-group 1
interface ATM1/1.7 point-to-point
pvc 1/179
bridge-group 1
interface ATM1/1.8 point-to-point
pvc 1/52
bridge-group 1
interface ATM1/1.9 point-to-point
pvc 1/32
bridge-group 1
interface ATM1/1.10 point-to-point
description "st-anthony"
pvc 1/36
bridge-group 1
interface ATM1/2
no ip address
shutdown
atm vc-per-vp 256
interface ATM1/3
no ip address
shutdown
atm vc-per-vp 256
interface BVI1
ip address 10.60.112.1 255.255.248.0
clns mtu 1514
ip classless
ip route 0.0.0.0 0.0.0.0 ATM0/0
ip route 10.60.0.0 255.255.0.0 10.60.120.1
ip route 10.60.112.0 255.255.248.0 BVI1
no ip http server
access-list 101 deny ip any 10.155.0.0 0.0.255.255
access-list 101 deny ip any 10.156.0.0 0.0.255.255
access-list 101 deny ip any 10.157.0.0 0.0.255.255
access-list 101 deny ip any 10.158.0.0 0.0.255.255
access-list 101 deny ip any 10.159.0.0 0.0.255.255
access-list 101 deny ip any 10.160.0.0 0.0.255.255
access-list 101 deny ip any 10.161.0.0 0.0.255.255
access-list 101 deny ip any 10.162.0.0 0.0.255.255
access-list 101 deny ip any 10.163.0.0 0.0.255.255
access-list 101 deny ip any 10.164.0.0 0.0.255.255
access-list 101 deny ip any 10.165.0.0 0.0.255.255
access-list 101 deny ip any 10.166.0.0 0.0.255.255
access-list 101 deny ip any 10.167.0.0 0.0.255.255
access-list 101 deny ip any 10.168.0.0 0.0.255.255
access-list 101 deny ip any 10.169.0.0 0.0.255.255
access-list 101 deny ip any 10.170.0.0 0.0.255.255
access-list 101 deny ip any 10.171.0.0 0.0.255.255
access-list 101 deny ip any 10.172.0.0 0.0.255.255
access-list 101 deny ip any 10.173.0.0 0.0.255.255
access-list 101 deny ip any 10.174.0.0 0.0.255.255
access-list 101 permit ip any any
bridge 1 protocol ieee
bridge 1 route ip
dial-peer cor custom
line con 0
line aux 0
login
line vty 0 4
login
line vty 5 15
login
end
07-29-2011 08:25 AM
I am not ATM expert but What was the IP address the 8510 was managed with? I see on the 3600
interface ATM0/0
atm pvc 1 0 5 qsaal
atm pvc 2 0 16 ilmi
interface BVI1
clns mtu 1514
ip classless
no ip http server
on the 8510
interface ATM0/0/1
no ip address
interface Ethernet0
no ip address
No ip addresses
No ip routes,
The 8510 has no IPv4 connectivity!
