C-921 intermittent internet cut off
dhaferbk
I have an intermittent internet cut off. The router becomes inaccessible by ssh. No ping also from internet and from inside.
Here is my running config:
Current configuration : 1878 bytes
! Last configuration change at 17:23:04 UTC Tue Apr 2 2024 by admin
version 15.8
service password-encryption
hostname R-0001
boot-start-marker
boot-end-marker
enable secret 5 $1$NsYq$38ERNeme81IFyY72QT/T6.
no aaa new-model
memory-size iomem 25
ip dhcp excluded-address 192.168.0.1 192.168.2.255
ip dhcp excluded-address 192.168.5.0 192.168.255.255
ip dhcp pool mainPool
import all
network 192.168.0.0 255.255.0.0
default-router 192.168.2.1
dns-server 192.168.2.1
ip domain name pathogenia.com
ip name-server 198.154.101.1
ip name-server 198.231.100.1
ip cef
no ipv6 cef
license udi pid C921-4P sn PSZ27421DXZ
username admin secret 5 $1$gIuU$wW06Vw/5SYLYZVTmsdA5L/
redundancy
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
ip address 55.71.7.250 255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet5
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip address 192.168.2.1 255.255.0.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 1 interface GigabitEthernet4 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet4 55.71.7.249
access-list 1 permit 192.168.0.0 0.0.255.255
access-list 101 permit udp any any eq domain
access-list 101 permit udp any eq domain any
control-plane
line con 0
password 7 07212E5841071C3A424359
login
line vty 0 4
password 7 14391D1F030A2F14717961
login local
transport input ssh
scheduler allocate 20000 1000
end
10 Replies 10
liviu.gheorghe
Hello @dhaferbk ,
can you also provide the output of the show logging command?
Regards, LG
*** Please Rate All Helpful Responses ***
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 58 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 58 messages logged, xml disabled,
filtering disabled
Exception Logging: size (8192 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 56 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (8192 bytes):
*Jan 2 00:00:00.309: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c900 Next reboot level = ipbasek9 and License = ipbasek9
*Apr 2 12:16:26.653: esw_mrvl_hw_init 4263 gsysSetRsvd2CpuEnables enBits=0x4009
*Apr 2 12:16:29.861: FBSD_HCD :VERBOSE :5020 xHCI version = 0x0100
*Apr 2 12:16:29.863: FBSD_HCD :VERBOSE :5023 32 bytes context size, 64-bit DMA
*Apr 2 12:16:29.863: FBSD_HCD :VERBOSE :5024 Total no. of ports : 8
*Apr 2 12:16:29.863: FBSD_HCD :VERBOSE :5026 Total no. of ports : 8, Max slots : 32
*Apr 2 12:16:29.863: BIOS/Rommon Already performed USB Handoff
*Apr 2 12:16:29.893: %LINK-3-UPDOWN: Interface GigabitEthernet4, changed state to down
*Apr 2 12:16:29.893: %LINK-3-UPDOWN: Interface GigabitEthernet5, changed state to down
*Apr 2 12:16:31.547: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4, changed state to down
*Apr 2 12:16:31.547: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet5, changed state to down
*Apr 2 12:16:32.541: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Apr 2 12:16:33.235: %SYS-6-PRIVCFG_DECRYPT_SUCCESS: Successfully apply the private config file
*Apr 2 12:16:33.279: %SYS-5-CONFIG_I: Configured from memory by console
*Apr 2 12:16:33.555: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C900 Software (C900-UNIVERSALK9-M), Version 15.8(3)M6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Fri 19-Feb-21 06:57 by prod_rel_team
*Apr 2 12:16:33.765: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Apr 2 12:16:33.765: %LINK-3-UPDOWN: Interface GigabitEthernet4, changed state to up
*Apr 2 12:16:33.971: %SYS-6-BOOTTIME: Time taken to reboot after reload = 120 seconds
*Apr 2 12:16:34.375: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to up
*Apr 2 12:16:34.765: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4, changed state to up
*Apr 2 12:16:35.271: %LINK-5-CHANGED: Interface GigabitEthernet5, changed state to administratively down
*Apr 2 12:16:36.279: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Apr 2 12:16:36.323: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to down
*Apr 2 12:16:36.367: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2, changed state to down
*Apr 2 12:16:36.411: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3, changed state to down
*Apr 2 12:16:38.911: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*Apr 2 12:16:50.833: %SSH-5-DISABLED: SSH 1.99 has been disabled
*Apr 2 12:16:50.837: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Apr 2 12:18:28.903: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Apr 2 12:18:29.903: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Apr 2 12:18:58.029: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
*Apr 2 12:22:49.969: %SYS-5-CONFIG_I: Configured from console by console
*Apr 2 12:23:01.945: %SYS-6-PRIVCFG_ENCRYPT_SUCCESS: Successfully encrypted private config file
*Apr 2 14:29:40.585: %DNSSERVER-3-BADQUERY: Bad DNS query from 192.168.2.110
*Apr 2 14:29:40.705: %DNSSERVER-3-BADQUERY: Bad DNS query from 192.168.2.110
*Apr 2 14:29:40.831: %DNSSERVER-3-BADQUERY: Bad DNS query from 192.168.2.110
*Apr 2 14:29:43.033: %DNSSERVER-3-BADQUERY: Bad DNS query from 192.168.2.110
*Apr 2 14:29:44.097: %DNSSERVER-3-BADQUERY: Bad DNS query from 192.168.2.110
*Apr 2 14:29:45.689: %DNSSERVER-3-BADQUERY: Bad DNS query from 192.168.2.110
*Apr 2 14:29:46.767: %DNSSERVER-3-BADQUERY: Bad DNS query from 192.168.2.110
*Apr 2 14:29:48.369: %DNSSERVER-3-BADQUERY: Bad DNS query from 192.168.2.110
*Apr 2 14:29:49.423: %DNSSERVER-3-BADQUERY: Bad DNS query from 192.168.2.110
*Apr 2 14:29:51.029: %DNSSERVER-3-BADQUERY: Bad DNS query from 192.168.2.110
*Apr 2 14:29:52.093: %DNSSERVER-3-BADQUERY: Bad DNS query from 192.168.2.110
*Apr 2 14:29:53.687: %DNSSERVER-3-BADQUERY: Bad DNS query from 192.168.2.110
*Apr 2 14:29:54.749: %DNSSERVER-3-BADQUERY: Bad DNS query from 192.168.2.110
*Apr 2 14:39:09.277: %SSH-4-SSH2_UNEXPECTED_MSG: Unexpected message type has arrived. Terminating the connection from 146.190.174.211
*Apr 2 16:21:10.350: %SSH-4-SSH2_UNEXPECTED_MSG: Unexpected message type has arrived. Terminating the connection from 198.235.24.145
*Apr 2 17:22:57.486: %DHCPD-4-PING_CONFLICT: DHCP address conflict: server pinged 192.168.3.18.
*Apr 2 17:23:03.156: %DHCPD-4-PING_CONFLICT: DHCP address conflict: server pinged 192.168.3.22.
*Apr 2 17:23:04.512: %SYS-5-CONFIG_I: Configured from console by admin on vty0 (192.168.2.113)
*Apr 2 17:23:10.240: %DHCPD-4-PING_CONFLICT: DHCP address conflict: server pinged 192.168.3.26.
*Apr 2 17:23:10.322: %DHCPD-4-PING_CONFLICT: DHCP address conflict: server pinged 192.168.3.28.
*Apr 2 17:23:10.324: %DHCPD-4-PING_CONFLICT: DHCP address conflict: server pinged 192.168.3.29.
*Apr 2 17:23:19.910: %SYS-6-PRIVCFG_ENCRYPT_SUCCESS: Successfully encrypted private config file
*Apr 2 17:26:26.220: %SYS-6-PRIVCFG_ENCRYPT_SUCCESS: Successfully encrypted private config file
*Apr 2 18:03:23.896: %DHCPD-4-PING_CONFLICT: DHCP address conflict: server pinged 192.168.3.49.
*Apr 2 19:07:24.946: %DHCPD-4-DECLINE_CONFLICT: DHCP address conflict: client 0152.de8a.667c.8e declined 192.168.3.53.
I don't see something alarming in the logs you provided.
You say "The router becomes inaccessible by ssh. No ping also from internet and from inside." - when the router becomes accessible again, what is the uptime of the router?
sho ver | in Uptime
Regards, LG
You get staitc IP from ISP ?
MHM
Yes, iti a static address frim an ISP.
Add
Ip name server 8.8.8.8 8.8.4.4
And
Ip dns server
Ip domain lookup
Then check
MHM
I have already my DNSs from my ISP provider. The main issue is that the router stop working after some hours of work - even pings stop in this case.
You have already DNS from your ISP but
import all
You use router IP as DNS server and this need two command I share above
Ip dns server
Ip domain lookup
Also you need to enlarge little your dns queue
ip dns server queue limit forwarder queue-size-limit
Why the router stop ping and ssh?
Because it busy send and resend DNS requests
MHM
try this basic configuration:
version 15.8
hostname R-0001
boot-start-marker
boot-end-marker
no aaa new-model
network 192.168.2.0 255.255.255.0
dns-server 8.8.8.8
ip cef
no ipv6 cef
redundancy
no ip address
no ip address
no ip address
no ip address
ip nat outside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip address 192.168.2.1 255.255.255.0
ip nat inside
no ip http server
ip dns server
access-list 1 permit 192.168.2.0 0.0.0.255
control-plane
line con 0
login
line vty 0 4
login local
transport input ssh
end
dhaferbk
I was suspecting the buffer size. For this reason I putted : memory-size iomem 25
I am waiting for the issue to come back again.
