First, Cisco Configuration Professional Express is no longer sold and supported.
You cannot download it from the following page (login required).
From now on, it may be difficult to use it for daily operation.
https://www.cisco.com/c/m/ja_jp/customer/cisco-start-user-site/download.html
I also connected to CCP Express with my C841M.
The operation was completed in the web browser, and it seemed that Java Runtime was not used.
※ We didn't launch external applications like SDM (Security Device Manager), which we used to say, or ASDM, which we say in ASA.
(Since my C841M is in regular use, I can't do it until I input the described configuration and check the validity.)
Since I have access to Web UI, I was worried whether the file of CCP Express is damaged or not.
This is the first step, but the CCP Express file is no longer available for download.
I wonder if the file can be replaced even if it is damaged.
