C-NIM-2T Module 2 or 4 port can be used
ilhambasuki
I have C8200-1N-4T and want to add port using C-NIM-2T. Datasheet is a little bit confusing with its wording.
On datasheet: 2x RJ-45/SFP groups. One port from each group can be used simultaneously
Is this mean I have to choose between RJ-45 or SFP for each group or I can utilize both ports for different purpose?
Ilham
Giuseppe Larosa
Hi, @ilhambasuki ,
your underst:anding is correct:
you can expect in interface mode:
media-type rj45! xxx
Hope to help
Giuseppe
Giuseppe Larosa
Hi, @ilhambasuki ,
Hope to help
Giuseppe
