C-NIM-X port numbering on C8300-1N1S-6T
Spawn
Hi guys, does anybody know what would be the slot bay numbers for NIM1? the onboard ones are all 0/0/X
C-NIM-X will take its pace in NIM1 slot.
NIM1 would it be 0/1/X or 1/0/X or 1/1/X? Cisco has confusing way of presenting the details.
LED
RJ-45 Gigabit Ethernet port (1G 0/0/0)
RJ-45 Gigabit Ethernet port (1G 0/0/2)
SFP/1 Gigabit Ethernet port (1G 0/0/4)
NIM Slot1
6
SM Slot1
7
RFID (Optional)
8
USB Type C (3.0) (USB 1)
9
USB Type A (3.0) (USB 0)
RJ-45 Console
11
Micro-USB Console
12
RJ-45 Gigabit Ethernet port (1G 0/0/1)
13
RJ-45 Gigabit Ethernet port (1G 0/0/3)
14
SFP/1 Gigabit Ethernet port (1G 0/0/5)
15
M.2 USB/NVMe storage
16
Device Label Tray
2 Accepted Solutions
Enes Simnica
Level 5
Level 5
hello @Spawn and great question man. SHORT ANSWER : The NIM1 slot is numbered 0/1/x
WHY , well:
  • 0= Chassis number (always 0 on single-chassis routers)
  • 1= Slot number (NIM1)
  • x= Port number on the NIM module
So if you install a module in NIM1, interfaces will be numbered like: 0/1/0, 0/1/1, etc. etc. Onboard ports stay as: 0/0/x
and of course, If u had a second NIM slot, it would be: 0/2/x....
if u need some links or docs, let me know, and hope it helps...
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
Spawn
so finally we have the answer, thank you all for taking the effort and looking into the details
------------------ show inventory ------------------
NAME: "Chassis", DESCR: "Cisco C8300-1N1S-6T Chassis"
PID: C8300-1N1S-6T     , VID: V02  , SN:
NAME: "NIM subslot 0/1", DESCR: "C-NIM-4X"
PID: C-NIM-4X          , VID: V01  , SN:
NAME: "subslot 0/1 transceiver 2", DESCR: "SFP+ 10GBASE-SR"
PID: SFP-10G-SR          , VID: V03  , SN:
NAME: "subslot 0/1 transceiver 3", DESCR: "SFP+ 10GBASE-SR"
NAME: "NIM subslot 0/0", DESCR: "Front Panel 6 ports Gigabitethernet Module"
PID: 4x1G-2xSFP        , VID: V01  , SN:
NAME: "subslot 0/0 transceiver 4", DESCR: "GE LX"
PID: GLC-LH-SMD          , VID: V01  , SN:
NAME: "module R0", DESCR: "Cisco C8300-1N1S-6T Route Processor"
NAME: "module F0", DESCR: "Cisco C8300-1N1S-6T Forwarding Processor"
PID: C8300-1N1S-6T     , VID:      , SN:
interface TenGigabitEthernet0/1/0
shutdown
interface TenGigabitEthernet0/1/1
shutdown
interface TenGigabitEthernet0/1/2
switchport
shutdown
interface TenGigabitEthernet0/1/3
switchport
shutdown
Enes Simnica
Level 5
Level 5
WHY , well:
-Enes
more Cisco?!
more Gym?!
Enes Simnica
Level 5
Level 5
also @Spawn my apologies man, I just noticed u’re a CCIE. Didn’t mean to dive into all the details, I know exactly what kind of beast you are!  Next time I’ll just drop the link and step back… LOL
HUGE RESPECT!
more Cisco?!
more Gym?!
M02@rt37
Hello @Spawn
According to the Catalyst 8300 Hardware Installation Guide, slot 0 is reserved for integrated ports and NIMs.
So, "user-installed" NIM occupy slot 1, meanning that any interfaces on a module in the NIM1 location appear as 0/1/X.
See here, "slot numbering" part:
https://www.cisco.com/c/en/us/td/docs/routers/cloud_edge/c8300/hardware_installation/b-catalyst-8300-series-edge-platforms-hig/m-overview.html#con_1057273
Best regards
Spawn
shutdown
shutdown
switchport
shutdown
switchport
shutdown
