C1111-8P IPSEC SITE TO SITE VPN
I'm planning to configure IPsec Site to Site VPN on C1111-8P Router. Is there anyone share configuration example need to do on router.
how many are you planning on having ?
default is 50mb throughput upgrade able to 250 with a performance ipsec license so it goes on that rather than the actual amount of tunnels , the data sheets do not e give a count
Pay as you grow: IPsec performance upgrade model ●Router IPsec capacity canbe increased with a remote performance-on-demand license upgrade (no hardware upgrade) for exceptional savings and CapEx budget manageme
FL-VPERF-8P-200(=) FL-VPERF-4P-100(=) IPSec Performance (VPERF) IPsec Performance: Additional 100 Mbps for ISR 1100-4P and 200 Mbps for ISR 1100-8P. Not applicable on C1109-2PLTE models.
https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/datasheet-c78-739512.pdf7
https://www.router-switch.com/pdf/c1111-8p-datasheet.pdf
https://www.google.com/search?q=Cisco+ISR+1000+Series-Platform+Spec&client=firefox-b-d&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjuyKGnobbhAhXOQxUIHeWvDZEQ_AUIDigB&biw=1704&bih=1036#imgrc=TD1aylxWcH473M:
5 Replies 5
the C1111 has software parity with the ISR4K, so the below, generic SVTI site to site VPN sample config should work:
C1111_1
service timestamps debug datetime
service timestamps log datetime
hostname C1111_1
no aaa new-model
ip subnet-zero
ip cef
crypto isakmp policy 1
encr aes
authentication pre-share
group 14
crypto isakmp key cisco123 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set TS esp-aes esp-sha-hmac
crypto ipsec profile PF
set transform-set TS
interface Tunnel0
ip address 172.16.1.1 255.255.255.0
load-interval 30
tunnel source 10.0.0.1
tunnel destination 10.0.0.2
tunnel mode ipsec ipv4
tunnel protection IPsec profile PF
interface GigabitEthernet0/0/0
ip address 10.0.0.1 255.255.255.252
interface Vlan1
ip address 192.168.10.1 255.255.255.0
ip classless
ip route 192.168.20.0 255.255.255.0 Tunnel0
line con 0
line aux 0
line vty 0 4
C1111_2
hostname C1111_2
no aaa new-model
ip subnet-zero
ip cef
encr aes
group 14
interface Tunnel0
ip address 172.16.1.2 255.255.255.0
tunnel source 10.0.0.2
tunnel destination 10.0.0.1
tunnel protection ipsec profile PF
ip address 10.0.0.2 255.255.255.252
interface Vlan1
ip address 192.168.20.1 255.255.255.0
ip classless
ip route 192.168.10.0 255.255.255.0 Tunnel0
line con 0
line aux 0
line vty 0 4
Georg,
Thanks for reply, but could you put please more light on command
Can i use my router outside interface Public ip  address instead of 0.0.0.0 0.0.0.0 in above command.
Also if there's any need to add ACL for internal ip subnet for both location to communicate.
VIshal
--> crypto isakmp key cisco123 address 0.0.0.0 0.0.0.0
The 0.0.0.0 0.0.0.0 address would be used if your routers have dynamically assigned addresses, if you have static public IP addresses you can by all means use those.
With (S)VTI VPNs you don't need access lists anymore, you just use static routes pointing to the tunnel interface (as in the example).
If you need detailed support on how to set up your VPN, post the full configurations of both routers...
Thanks Georg,
Could you please let me know How many IPSEC Site to Site VPN (Count) supports by C1111-8P Router
Regrads,
Vishal
