C1111-8P ROAS Issue
Jordan023
Beginner
Beginner
Find below is my running-config
Router#show run
Building configuration...
Current configuration : 4503 bytes
! Last configuration change at 10:08:55 UTC Thu Dec 2 2021 by cisco
version 16.9
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa login success-track-conf-time 5
aaa session-id common
clock timezone UTC 10 0
ip dhcp pool webuidhcp
ip dhcp pool WEBUIPool
network 192.168.1.0 255.255.255.0
subscriber templating
license udi pid C1111-8PLTELA sn FGL2410L5Z0
no license smart enable
diagnostic bootup level minimal
redundancy
mode none
controller Cellular 0/2/0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
ip address 10.151.58.254 255.255.255.0
speed 1000
no negotiation auto
interface GigabitEthernet0/0/0.59
encapsulation dot1Q 59
ip address 10.151.59.254 255.255.255.0
interface GigabitEthernet0/0/0.60
encapsulation dot1Q 60
ip address 10.151.60.254 255.255.255.0
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Cellular0/2/0
ip address negotiated
ipv6 enable
interface Cellular0/2/1
no ip address
shutdown
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication aaa
ip http secure-server
control-plane
banner login ^CUnauthorized Access is Prohibited - RTitsupport^C
line con 0
transport input none
stopbits 1
line vty 0 4
end
Router#
I have created the VLANS (59 & 60) with no IP, assigned each respectively to port 24  and port 25 on my swich.
Port 24
"switchport mode access"
"switchport access vlan 59"
Port 25
"switchport access vlan 60"
I still could not have the two devices connected to the two port communicating.
Kindly assist and advise on where I could make it to work.
5 Replies 5
pieterh
VIP Engager VIP Engager
VIP Engager
router interface GigabitEthernet0/0/0 is connected to what port on your switch ?
this port needs to be configured as a trunk
Richard Burts
VIP Community Legend VIP Community Legend
The point about the connection from switch to router is a good point. Posting the switch config might be helpful. If you do not want to post the switch config then please post the output of show interface trunk from the switch. It might also be helpful if you post the output of show interface status from the switch.
You have 3 subnets in the router config associated with Gig0/0/0. Are there 3 vlans on the switch?
I do not see DHCP pools for vlans 59 and 60. Are the hosts connected in those vlans configured manually? Can you verify and post the IP address, mask, and default gateway for both of those hosts? Is the default gateway on each host the corresponding router IP in that subnet? Posting the content of the arp table from each of those hosts might be helpful.
Rick
It is connected to Port 24 of my switch, the port is trunked
I am puzzled. In the original post you give us this
Port 24
Now you tell us that port 24 is trunked. Perhaps you would post the output of show interface trunk from the switch to help us understand the environment?
Rick
also post the running configuration of your switch:
sh run
and the output of:
show cdp neighbors
Recognize Your Peers
