C1111-8P - WEBUI only monitoring dashboard no router config
michael122
i have setup the WEBUI as suggest by the following link:
"https://www.cisco.com/c/en/us/td/docs/routers/access/isr1100/software/configuration/xe-17/isr1100-sw-config-xe-17/mgmt_interfaces.html"
I believe thats the correct approach given my software version (17.3.4a), however, apart from the monitoring dashboard, there is nothing i can do in the Web UI, i think there should be additional tabs for configuration/administration but they do not show up, i ve included a screenshot how it looks like.
In its current form the Web UI is not of much use for me. Please help.
Best
Michael
michael122
Hi, i have found a solution in post for a different router model, but also works for this one
"Please configure 30 lines for line vty in order to resolve this issue:
line vty 0 30
michael122
line vty 0 30
Can someone please explain how that fixed the issue?  What does the number of vty lines have to do with the menu system on the webui? It actually worked but I don't understand why.  I don't see how the two things are related to each other.
