C1113-8P bridge domain throughput issue? (Router as a modem)
Hi folks - I'm trying to setup a C1113 as a modem by bridging the Ethernet0/2/0 and GigabitEthernet0/0/0 interfaces.
For the purposes of this exercise assume we're trying to initiate a PPPoE connection from a windows 10 laptop - at least that's the test setup. I have successfully achieved this on an old 887VA (config below), and i'm now trying to replicate on the C1113 (config also below) - which is working but the throughput on the C1113 is nowhere near what I expect.
I have a 80/20 VDSL circuit here in the UK, which uses VLAN 101 by the service provider.
On the 887VA I am getting 76Mbps throughput, but only 29Mbps on the C1113 - same circuit and same cable from the NTU to the router.
Any ideas why download through the C1113 is through the floor? Both configs work, I can dial the PPPoE connection in from a laptop, see my public IP on the laptop, and connectivity is working. I've switched between both routers a dozen times and the results are consistent.
To prove the C1113 is negotiating the correct VDSL speed as per the 887VA, I configured the C1113 as a typical router, and I can get 76Mbps through it no problem. In both cases on both routers I get 19Mbps upload which I expect.
Ultimately I will connect the C1113 to my ISR4331 with the dialer on the 4331 (to get the public IP's on the 4331) - Upgrading to G.Fast next week and there are no NIM modules to my knowledge which support G.Fast. Current NIM-VAB-A will be coming out of the 4331.
Cisco 887VA config
version 15.4
hostname gateway
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip cef
no ipv6 cef
license udi pid C887VA-K9 sn FCZ1840C073
controller VDSL 0
interface ATM0
no ip address
no ip route-cache
shutdown
no atm ilmi-keepalive
interface Ethernet0
description **VDSL**
no ip address
no ip route-cache
interface Ethernet0.101
description **Tagging for PPPoE (VDSL0)**
encapsulation dot1Q 101
no ip route-cache
bridge-group 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
no ip address
ip virtual-reassembly in
no ip route-cache
bridge-group 1
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
bridge 1 protocol ieee
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
Cisco C1113 config
version 16.9
service password-encryption
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname gateway
boot-start-marker
boot-end-marker
enable secret **REMOVED**
enable password **REMOVED**
no aaa new-model
no ip routing
ip domain name **REMOVED**
subscriber templating
license udi pid C1113-8P sn FCZ2324910D
no license smart enable
diagnostic bootup level minimal
username administrator password 7 **REMOVED**
redundancy
mode none
bridge-domain 101
controller VDSL 0/2/0
operating mode vdsl2
modem ukfeature
vlan internal allocation policy ascending
bridge irb
interface GigabitEthernet0/0/0
no ip address
negotiation auto
no cdp enable
service instance 101 ethernet
encapsulation untagged
bridge-domain 101
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface ATM0/2/0
no ip address
shutdown
atm oversubscribe factor 2
no atm enable-ilmi-trap
interface Ethernet0/2/0
mtu 1500
no ip address
negotiation auto
no cdp enable
encapsulation dot1q 101
rewrite ingress tag pop 1 symmetric
bridge-domain 101
interface Vlan1
no ip address
ip http server
ip http authentication local
ip ssh version 2
control-plane
line con 0
transport input none
stopbits 1
line vty 0 4
login local
transport input ssh
0 Replies 0
