C2960L-SM routing
johnchrapkowski
Anyone know why I can't select my other VLANs for this routing ( I have 3)?  Also I don't see the routes when I run show ip route after adding them, applying and saving!  What's up with that?
14 Replies 14
M02@rt37
Hello @johnchrapkowski
C2960L-SM  is a L2 Switch. No routing (L3) capabilities. What is the IOS image ?
Best regards
I thought so as well, but the documentation seems to indicate it can support up to 200 routes
its been Long i have worked on Cat2K models - can you post show License - and what SDM template you have ?
EDIT :
as per the document you can create VLAN and SVI using GUI :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960l/software/15-2_6_e/configuration_guide/b_2960L_SM_1_0_UG/b_2960L_chapter_01.html#id_91321
BB
Thank you, I thought this as well, but why would it have the GUI allow me to set these things?  Also some documentation seems to indicate it can do limited routing.
This image is from the Cisco docs on my exact switch:
Here is the version info:
Thu Nov 30 2023 11:22:08 GMT-0600 (Central Standard Time)
#show ver
Cisco IOS Software, C2960L Software (C2960L-UNIVERSALK9-M), Version 15.2(6)E2b, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 20-Nov-18 21:04 by prod_rel_team
ROM: Bootstrap program is C2960L boot loader
BOOTLDR: C2960L Boot Loader (C2960L-HBOOT-M) Version 15.2(6r)E1, RELEASE SOFTWARE (fc1)
Switch uptime is 4 weeks, 2 minutes
System restarted at 17:39:34 UTC Thu Nov 2 2023
System image file is "flash:c2960l-universalk9-mz.152-6.E2b/c2960l-universalk9-mz.152-6.E2b.bin"
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960L-SM-48TS (Marvell PJ4B (584) v7 (Rev 2)) processor (revision E0) with 524288K bytes of memory.
ammahend
As suggested this is an L2 switch, however you can try configuring command “ip routing” and then try show ip route.
-hope this helps-
Unfortunately I cannot, I can run the command and thats how I see thats it's not applying the routes, but I cannot edit from the CLI.  This is a 2906 L-SM  which is ONLY GUI configurable.  The config term command doesn't even exist in the CLI
Why you use gui'
Use cli and try add other vlan then use it for static route
MHM
This is C2960L-SM  SM=smart manage, which is ONLY GUI (not so smart if you ask me)
Even so
I think there is tab vlan you can add vlan anc it ip then you can use it in static route.
Now there is no vlan for static  because you dont add vlan.
MHM
I tried this (or I think I did).  I create a new VLAN (3) and added the port that this new device is connected to on that vlan 3.  I then added a route using interface to VLAN3 with next hop IP of the device (the device is a router by the way).
Thank you so much for the information but my switch is 2960L-SM
johnchrapkowski
I'm going  to get a new switch.  I don't think this supports routing at all, or I have the wrong SMD loaded or something.  Thanks all
sure let us know how you progressing.
BB
