C3850 QoS Service-policy output
I try to apply the following config. The command interpreter does not seem to allow me to do that, no error message but no policy map is attached to any interface. I tried to attach it to the physical interfaces too, without success. Any known reasons for that behaviour?
class-map match-any CM-OUTPUT-DROPS
match vlan 1500 1560 3012 4000
policy-map PM-OUTPUT-DROPS
 class class-default
 bandwidth percent 100
interface Port-channel1
 service-policy output PM-OUTPUT-DROPS
7 Replies 7
Joseph W. Doherty
Regarding no error messages, did you also check you syslog?
You might try bandwidth percent 99 or bandwidth remaining percent 100.
Hi Joseph
The hint with the log was good, first it did not like the config on Port-Channel interfaces but also when I configured it to the physical interfaces it looked like that:
Mar 9 10:55:11.399: %QOS-6-POLICY_INST_FAILED:
Service policy installation failed
Mar 9 10:58:02.467: Order of classes in policy name PM-OUTPUT-DROPS is not consistent with
installed policy
I cannot yet see what in the order of my policy should be wrong since it consists of one class only but I'll sure find out. The 99% by the way lead to the same error.
I tried to rephrase the class-map, without success:
match vlan 1500
match vlan 1560
match vlan 3015
match vlan 4000
The fun thing is that I have a pretty similar config, only with an IP access group on a 3650 that is running perfectly. I guess it must have something to do the the VLAN-based matching criteria.
Thanks for your hints. I'll keep trying.
I found this page, which puzzles me a bit:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/200729-Common-QoS-error-messages-on-Catalyst-38.html#anc11
It says something like
Restriction(s):
  • The classification sequence for all wired queuing-based policies should be the same across all wired upstream ports (TenGigabit Ethernet), and the same for all downstream wired ports (Gigabit Ethernet).
Workaround:
  • Use the same order of the classes as the first configured queueing-based policy-map. This message is not shown if you apply the policy map on any interface of 10GE Module
So in other words this means that I can have one input and one output policy over all ports in one module. Or am I wrong in my interpretation? It would at least explain my issues, I'd have to find another solution in this case.
Yea, it could mean that as "under the covers" Catalyst switches support QoS via hardware.
I also just notice you're trying to apply the service policy to a port-channel.  You might also try applying to the individual port-channel ports.
Hi Joseph
As I said before I also tried to apply the policy-map to physical interfaces with the same result.
QoS in switches sure must be a hardware thing, otherwise the switching performance would be degraded greatly. The difficulty is to find out how to instruct each device to do what I want (or rather to know what the device allows me to configure QoS-wise). I have not yet found any documentation that lets me dig into each box to understand the inner workings.
Thanks for your ideas
P.S. Sorry for the one star. I meant to give 5 but I can't handle the tool.....
Yup, QoS in switches is very much a hardware thing, for the reasons you note.
Although you cannot generally "see" the impact against particular/specific flows, you can often infer much from the QoS stats that device does provide especially relative to your QoS configuration.
Hi Matthias,
Can I ask you which IOS-XE was your 3850 running at that time? We ran into the same issue and we got
but no further hint or message like the one you were getting. Our 3850 is running 3.6.8E.
I suspect the reason we can't configure a different service-policy out on one single Gix/0/x interface is the same in both our cases (BTW thanks for that URL) however I was wondering why we don't get the extra info.
Cheers!
F.
