C3900 Module Slot problem
concentrix-mis
Hi Team,
We buy new router and install 3 nm-hdv2-2T1/E1 module, but module is unknown see below logs for perusal.
NAME: "Cisco Services Performance Engine 200 for Cisco 3900 ISR on Slot 0", DESCR: "Cisco Services Performance Engine 200 for Cisco 3900 ISR"
PID: C3900-SPE200/K9   , VID: V05 , SN: FOC18161V21
NAME: "Network Module Adapter for SM Slot on Slot 1", DESCR: "Network Module Adapter for SM Slot"
PID: SM-NM-ADPTR       , VID: V01, SN: FOC14300M1N
NAME: "Unknown on Slot 1", DESCR: "Unknown"
PID: NM-HDV2-2T1/E1    , VID: V05 , SN: FOC14346TEF
NAME: "Network Module Adapter for SM Slot on Slot 2", DESCR: "Network Module Adapter for SM Slot"
PID: SM-NM-ADPTR       , VID: V01, SN: FOC14300M98
NAME: "Unknown on Slot 2", DESCR: "Unknown"
PID: NM-HDV2-2T1/E1    , VID: V05 , SN: FOC14346T9K
>Show diag - > it show all the slots
>show ip int brief - > serial slot not showing
Any idea on this? we try to update the firmware already.
Okay,
Here is another challenge.Could you please run the following command:
Show diag 1
Under Slot 1: Look out for FRU Part Number     NM-32A= >>>  If you happen to see NM-32A as the FRU part then its not supported on this router.
Details:
http://www.cisco.com/c/dam/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/aag_c07_563807.pdf
An NM-32A is not supported on the 39xx routers
An SM-32A is supported
SM-32A
IP Base
2911-3945E
15.1(4)M2, 15.2(1)T1, 15.2(2)T for Cisco 3900 Series
15.1(4)M3 for Cisco 2900 Series
Hope this helps
Inayath
*********Plz dont forget to rate if this info is helpfull.******
5 Replies 5
InayathUlla Sharieff
Please check this basic release:
Cisco 3925, 3945
 Cisco IOS Software Release 15.0(1)M
• "UC Technology" images
• 1 GB DRAM
• 256 MB Flash
Still the same..  I already try this ff firmware
246   55203528 Sep 11 2014 13:18:46 +00:00 c3900-universalk9-mz.SPA.150-1.M1.bin
247   90071052 Sep 11 2014 14:19:08 +00:00 c3900-universalk9-mz.SPA.152-4.M6a.bin
Logs
*Sep 11 14:25:56.445: %PA-3-NOTSUPPORTED: PA in slot1 (Unknown (type 987)) is not supported on this image/licenses enabled. Please issue "show diag" CLI command to display the PA information, verify it is supported and, if applicable, ensure the correct license key is installed. A newer image version or license key may be needed.
Any idea?
Okay,
Show diag 1
Details:
SM-32A
IP Base
2911-3945E
Hope this helps
Inayath
NM-HDV2-2T1/E1 Unif. Comm. 2911 - 3945E 12.3(8)T4
Where can we download 12.3(8)T4? where seeing 15 series only.
Thats not available for 3945E.
But still you insist then log a tac case and check.
