c3945 - %PA-3-NOTSUPPORTED: PA in slot1 (Unknown (type 99))
craig pardo
Trying to find a hardware compatibility matrix for SM-NM-Adapter and the 3945.
I am attempting to use an async-32A network module in a 3945.  I want to use this device as a high density terminal server.  Is there an IOS for the 3945 that is compatible with this configuration?
Here is my sh ver output
3945b#sh ver
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.1(4)M7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 16-Sep-13 03:05 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M13, RELEASE SOFTWARE (fc1)
3945b uptime is 17 minutes
System returned to ROM by reload at 19:27:50 UTC Wed Feb 12 2014
System restarted at 19:29:23 UTC Wed Feb 12 2014
System image file is "flash:c3900-universalk9-mz.SPA.151-4.M7.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE150/K9 with 983040K/65536K bytes of memory.
Processor board ID FTX1644AJCE
5 Gigabit Ethernet interfaces
1 Serial interface
18 terminal lines
4 Channelized T1/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C3900-SPE150/K9       xxxxxxx
Technology Package License Information for Module:'c3900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            None          None           None
data          datak9        Permanent      datak9
Here is the entire error I am getting
Feb 12 19:29:52.959: %PA-3-NOTSUPPORTED: PA in slot1 (Unknown (type 99)) is not supported on this image/licenses enabled. Please issue "show diag" CLI command to display the PA information, verify it is supported and, if applicable, ensure the correct license key is installed. A newer image version or license key may be needed.
I issue a sh diag and get this:
3945b#sh diag 1
Platform mid-plane:
        PCB Serial Number        : FOC16347KT3
        Hardware Revision        : 1.0
        Part Number              : 73-12222-02
        Top Assy. Part Number    : 800-31577-02
        Board Revision           : C0
        Deviation Number         : 0
        Fab Version              : 02
        Product (FRU) Number     : CISCO3945-CHASSIS
        Version Identifier       : V02
        CLEI Code                : IPMN310DRA
        Chassis Serial Number    : FTX1644AJCE
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 36 33 34 37 4B 54 33 40
          0x10: 06 1B 41 01 00 82 49 2F BE 02 C0 46 03 20 00 7B
          0x20: 59 02 42 43 30 88 00 00 00 00 02 02 CB 91 43 49
          0x30: 53 43 4F 33 39 34 35 2D 43 48 41 53 53 49 53 89
          0x40: 56 30 32 00 C6 8A 49 50 4D 4E 33 31 30 44 52 41
          0x50: C2 8B 46 54 58 31 36 34 34 41 4A 43 45 C4 08 00
          0x60: 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 1:
        SM-NM-ADPTR
        Port Adapter is analyzed
        Port Adapter insertion time 00:06:27 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC16400CD8
        Part Number              : 73-12434-04
        Top Assy. Part Number    : 800-32481-01
        Board Revision           : G0
        Deviation Number         : 129133
        Fab Version              : 05
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : SM-NM-ADPTR
        Version Identifier       : V01
          0x00: 04 FF C1 8B 46 4F 43 31 36 34 30 30 43 44 38 40
          0x10: 05 F4 41 01 00 82 49 30 92 04 C0 46 03 20 00 7E
          0x20: E1 01 42 47 30 88 00 01 F8 6D 02 05 03 00 81 00
          0x30: 00 00 00 04 00 CB 8B 53 4D 2D 4E 4D 2D 41 44 50
          0x40: 54 52 89 56 30 31 00 D9 03 40 C1 CB F3 00 03 40
          0x50: 0B E3 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Unknown (type 99) Port adapter
        Port adapter is disabled
        Port adapter insertion time unknown
        Hardware revision 0.1           Board revision H0
        Serial number     29436145      Part number    800-02245-06
        FRU Part Number     NM-32A=
        Test history      0x0           RMA number     00-00-00
        EEPROM format version 1
          0x00: 01 63 00 01 01 C1 28 F1 50 08 C5 06 00 00 00 00
          0x10: 88 00 00 00 02 11 13 00 FF FF FF FF FF FF FF FF
          0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x30: FF FF FF FF FF FF FF FF FF FF FF FF
acampbell
Craig,
http://www.cisco.com/c/dam/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/aag_c07_563807.pdf
An NM-32A is not supported on the 39xx routers
An SM-32A is supported
SM-32A
IP Base
2911-3945E
15.1(4)M2, 15.2(1)T1, 15.2(2)T for Cisco 3900 Series
15.1(4)M3 for Cisco 2900 Series
Hope this helps
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
acampbell
Craig,
SM-32A
IP Base
2911-3945E
Hope this helps
Alex.
Thanks.  I figured it wasn't compatible, but I couldn't find that document.
