C4507r rate-limit question
hcintron
Hi Everyone.
  is it possible to do an equivalent to a rate-limit (CAR) on a C4507r?  What im looking to do is be able to have various rate-limits on a various vlan for both upload and download.  I've used the rate-limit (CAR) on a router but on the C4507r it looks like (CAR) is not allowed.
Thank You
Michael Johnson
I assume you mean applying rate limiting capabilities on layer 3 SVI's?
You can use the rate-limit command in interface config mode as well as the modular qos cli (MQC);
class-map
policy-map vlanX
interface vlanX
service-policy .....
mike
Hi Mike.
  Thanks for the reply.  If I enter a interface vlanxxx I cannot add the rate-limit command:
spare_equipment(config)#int vlan800
spare_equipment(config-if)#r?
% Unrecognized command
I did read the "Applying QoS Features Using the MQC"  If I understand it correctly, if I have 2 policies
"test one" will have a download of 6m and upload of 4m
"test two" will have a download of 2m and upload of 1m
I would do the following:
! ********************* test one
class-map match-all test
  description test rate-limit
match any
policy-map vlan800in
class test
    police 6000000 bps 8000 byte conform-action transmit exceed-action drop
policy-map vlan800out
class test
    police 4000000 bps 8000 byte conform-action transmit exceed-action drop
! ******************** test 2
class-map match-all test2
  description test2 rate-limit
match any
policy-map vlan900in
class test2
    police 2000000 bps 8000 byte conform-action transmit exceed-action drop
policy-map vlan900out
class test2
    police 1000000 bps 8000 byte conform-action transmit exceed-action drop
! ************** applied
interface Vlan800
ip address 10.94.0.2 255.255.255.0
service-policy input vlan800in
service-policy output vlan800out
interface Vlan900
ip address 10.95.0.2 255.255.255.0
service-policy input vlan900in
service-policy output vlan900out
is this correct?
Hi Hector,
If you are planning to apply the service-policy under the SVI, you must configure the physical interfaces with the qos vlan-based command.
Additionally, you can avoid configuring the class-map and instead use the policy-map with the class class-default.
Another note, the accuracy of the policer configured is +/- 1.5 % so you will experience traffic over the policed limit.
For more information, I highly suggest you read the documentation on implementing QoS on 4500 for any other caveats you may face
depending upon the hardware that is used.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/52sg/configuration/guide/qos.html#wp1461453
Edison.
