01-10-2012 08:20 AM - edited 03-04-2019 02:51 PM
HI,
For an activity on the client's last night.
we install a card WS-X6704-10GE in slot 3 in cisco 7600S.. when installing the card into the router showed us the following error:
%C6KPWR-SP-4-DISABLED: power to module in slot 4 set off (Fabric channel errors)
The slot 3 works well. The failure occurs in slot 4 does not participate in the activity. That's the weird thing.
Also install another card in the slot 4, on a trial basis. and continued with the same problem.
Thanks for support
Raul
01-10-2012 12:23 PM
Hi Raul,
I have seen similar issues on Cisco 6500 series chassis'. I have had to replace the chassis itself and from the symptoms you are describing it seems you are also experiencing the same problem.
Fabric channel errors occur when there is a issue with a slot communicating with the supervisor(s). I would recommend replacing the chassis.
02-07-2013 12:04 PM
I'm having the *exact same problem. Three different types of cards (WS-X6748-GE-TX, WS-X6716-10GE,
WS-X6724-SFP) won't boot in slot 4 due to "Fabric channel errors", but those same cards work in other slots.
We've tried a different SUP in the chassis, and a different chassis!!
I have a TAC case open and will update on progress.
6500#sh mod
Mod Ports Card Type Model Serial No.
3 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX
4 24 CEF720 24 port 1000mb SFP WS-X6724-SFP
5 2 Supervisor Engine 720 (Active) WS-SUP720-3BXL
8 16 CEF720 16 port 10GE WS-X6716-10GE
Mod MAC addresses Hw Fw Sw Status
3 001e.4a69.d95c to 001e.4a69.d98b 2.7 12.2(14r)S5 12.2(33)SXJ3 Ok
4 0011.9339.51b0 to 0011.9339.51c7 2.1 12.2(14r)S5 12.2(33)SXJ3 PwrDown
5 0013.7f0a.e42c to 0013.7f0a.e42f 4.5 8.5(2) 12.2(33)SXJ3 Ok
8 0007.7d38.5ee8 to 0007.7d38.5ef7 1.0 12.2(18r)S1 12.2(33)SXJ3 Ok
Mod Sub-Module Model Serial Hw Status
3 Distributed Forwarding Card WS-F6700-DFC3BXL 5.3 Ok
4 Distributed Forwarding Card WS-F6700-DFC3BXL 5.3 PwrDown
5 Policy Feature Card 3 WS-F6K-PFC3BXL 1.8 Ok
5 MSFC3 Daughterboard WS-SUP720 2.7 Ok
8 Distributed Forwarding Card WS-F6700-DFC3C 1.4 Ok
Mod Online Diag Status
3 Pass
4 Not Applicable
5 Pass
8 Pass
6500#
