Bookmark
Subscribe
935
C8200-1N-4T Router. ZBFW passing SCTP
Karma0
Does anybody knows how I can pass/allow just SCTP traffic between two different security zones?
zone security ZONE_OUTSIDE
zone security ZONE_INSIDE
I also have an extended ACL in which it is not possible to allow only the sctp protocol.
I only get it to work if I allow IP traffic in the ACL (it is not feasible to allow all IP traffic for security reasons)
class-map type inspect match-any CMAP_PROTOCOLS_INSPECT_OUTSIDE_TO_IN
    match protocol sctp
ip access-list extended ACL_OUTSIDE_IN
   permit sctp ip_1 ip_2
   permit ip ip_1 ip_2 (This option is not secure)
PD. We are trying with IOS XE 17.12.3a firmware but this does not work. ¿Any workaround?
8 Replies 8
This all config ?
Where is config of policy and zone pair?
Check this
https://www.cisco.com/c/en/us/support/docs/security/ios-firewall/98628-zone-design-guide.html
MHM
Hi MHM, please see the rest of configuration I am posting later.
Checking the arcticle you linked, SCTP is nos mentioned at all, and it states that configuring ZBFW class-maps are specified for layer 4 protocols (TCP UDP and ICMP). No mention for SCTP protocol.
the guide is how you config zone class/policy/pair
and if your router support match protocol sctp then it can filter it
what you need is
1- class match all
A- match sctp protcol
B- match acl
2- policy use class above and action inspect
3- zone pair from IN to OUT use policy above <<- you can other direction from OUT to IN
MHM
Hello
fyi the protocol match needs to before any  match on a acl
can you post the following :
sh policy-firewall config all
Edited - have you checked if sctp is listed as an application protocol ?
Kind Regards
Paul
Hi, the configuration include policy-maps class-maps, zpairs... and it works if matching protocols different than SCTP. Configuration is as follows:
!!!!!!!!!!!ASIGNING INTERFACES TO ZONES !!!!!!!!!!!!!
interface GigabitEthernet0/0/0
      zone-member security ZONE_OUTSIDE
interface GigabitEthernet0/0/1
      zone-member security ZONE_INSIDE
!!!!!!!!!!!!!DEFINING SECURITY ZONES!!!!!!!!!!!!!!!!!!
!!!!!!!!!!!!!DEFINING CLASS-MAP!!!!!!!!!!!!!!!!!!!
class-map type inspect match-any CMAP_PROTOCOLS_INSPECT_INSIDE_TO_OUT
     match protocol h323
     match protocol sctp
     match protocol h323
     match protocol sctp
class-map type inspect match-all CMAP_INSIDE_TO_OUT
     match access-group name ACL_INSIDE_OUT
class-map type inspect match-all CMAP_OUTSIDE_TO_IN
     match access-group name ACL_OUTSIDE_IN
 !!!!!!!!!!!!DEFINING POLICY-MAPS!!!!!!!!!!!!!!!!!!!!
policy-map type inspect PMAP_INSIDE_TO_OUT
    class type inspect CMAP_PROTOCOLS_INSPECT_INSIDE_TO_OUT
        pass
    class type inspect CMAP_INSIDE_TO_OUT
       inspect
    class class-default
       drop log
policy-map type inspect PMAP_OUTSIDE_TO_IN
    class type inspect CMAP_PROTOCOLS_INSPECT_OUTSIDE_TO_IN
        inspect
    class type inspect CMAP_OUTSIDE_TO_IN
       inspect
   class class-default
 !!!!!!!! DEFINING ZONE-PAIRS!!!!!!!!!
zone-pair security ZPAIR_OUTSIDE_TO_IN source ZONE_OUTSIDE destination ZONE_INSIDE
      service-policy type inspect PMAP_OUTSIDE_TO_IN
zone-pair security ZPAIR_INSIDE_TO_OUT source ZONE_INSIDE destination ZONE_OUTSIDE
     service-policy type inspect PMAP_INSIDE_TO_OUT
 !!!!!!!! DEFINING ACL!!!!!!!!!
ip access-list standard ACL_INSIDE_OUT
      permit any
     “Permit only sctp protocol”
FW#sh policy-map type insp zone-pair PMAP_INSIDE_TO_OUT/PMAP_OUTSIDE_TO_IN
share these output
MHM
any update?
MHM
Hello
@Karma0 wrote:.
Apologies for keep asking this, but is sctp actually showing as a application protocol, if it doesn't them you WILL need to used an ACL to specify the port number and obtain a match for it traffic??
Alternatively you could try downloading a newer PDLM for the rtr to see if that includes a SCTP application?
Kind Regards
Paul
