c880 ISR interfaces and routes not active
nmdc.kzstan
There is a strange problem with :c880data-universalk9-mz.150-1.M4.bin IOS. I can't ping gateway IP address and
"sh ip route" does not show any routes.
interface FastEthernet4
ip address a.b.82.66 255.255.255.0
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 a.b.82.65
yourname#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is not set
yourname#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0              unassigned      YES unset  down                  down
FastEthernet1              unassigned      YES unset  down                  down
FastEthernet2              unassigned      YES unset  down                  down
FastEthernet3              unassigned      YES unset  down                  down
FastEthernet4              a.b.82.66    YES NVRAM  up                    up
Vlan1                      10.10.10.1      YES NVRAM  down                  down
Hi Guys,
   Just add a "ip routing" command on it. If it still does not work, please post your current configuration,excluding sensitive information.
   But you should ping a.b.82.65 without any problem if ISP allows you to do.
HTH,
Toshi
7 Replies 7
Hi Guys,
HTH,
Toshi
Hi Toshi,
Computer pings gateway without problem with the same network configuration. Sth wrong with 880 isr.
"ip routing" doesn't appear in config after executing, maybe because it is a default.
Building configuration...
Current configuration : 3251 bytes
! Last configuration change at 09:23:32 UTC Thu May 5 2011 by admin
version 15.0
no service pad
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
   import all
   network 10.10.10.0 255.255.255.248
   default-router 10.10.10.1
   lease 0 2
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
license udi pid CISCO881-K9 sn FCZXXXXXXXX
username admin privilege 15 secret 5 XXXXXXXXXXXXXXXXXXXXXX
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip access-list extended ACCESS
permit ip any any
access-list 23 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class ACCESS in
   Okay. Let me check things first.
1. PCs can ping 10.10.10.1(Gateway). Right?
2. Router can ping a.b.82.65. Right?
3. Do you want PCs to connect to the internet. Right? If so you need NAT configuration there.
    You have to connect Lan interface on the router to bring interface-vlan1 up.
HTH,
Toshi
For the moment I want to be able to ping a.b.82.65 from router CLI. Router can't even ping it's fa4 interface IP adress.
I've configured several routers with 12.4 IOS before and never came across such a problem. Maybe there was a change in 15 IOS
and network features should be activated first?
yourname#ping a.b.82.66
Sending 5, 100-byte ICMP Echos to a.b.82.66, timeout is 2 seconds:
Success rate is 0 percent (0/5)
   It's wired.
   Please connect the lan interface and then ping 10.10.10.1 from the router itself.  I just wanna know what's happing with your router. Just try shut/no shut on your Fa4 for testing.
HTH,
Toshi
Got it working by deleting IP address, entering "ip routing" and configuring IP address after that.
Thank you Toshi.
    You tried it yourself  .  Okay I give you 5 as well.
Good Job!
Toshi
