01-17-2014 02:04 AM - edited 03-04-2019 10:06 PM
I have two sims.
profile 1 for slot 0
profile 2 for slot 1
But sim in slot 1 is registering with profile 1 and after 1 hour
cellular 0 gsm sim activate slot 1
controller Cellular 0
gsm sim profile 2 ims 1 slot 1
gsm failovertimer 7
sh cellular 0 profile
Profile 1 = ACTIVE **
PDP Type = IPv4
PDP address = 10.154.38.157
Access Point Name (APN) = www.kyivstar.net
Authentication = None
Username:
Password:
Primary DNS address = 193.41.63.161
Secondary DNS address = 193.41.63.162
Profile 2 = INACTIVE*
PDP Type = IPv4
Username:
Password:
Profile 3 = INACTIVE
PDP Type = IPv4
Access Point Name (APN) = 3g.utel.ua
Username:
Password:
* - Default profile
Configured default profile for active SIM 1 is profile 2.
Jan 17 08:56:43.895: TTY0: pause timer type 1 (OK)
Jan 17 08:56:43.895: To Activate SIM powering off the modem
Jan 17 08:56:44.611: [Cellular0]:CALLCTRL RX Link Status Indication (218 bytes):
00 DA 78 00 01 01 00 D6 03 16 00 55 00 41 00 2D
00 4B 00 59 00 49 00 56 00 53 00 54 00 41 00 52
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 4C 49 4E 4B 20 44 4F 57 4E 00 00 00 00
00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00
00 00 ED 00 ED 04 00 00 00 00 00 00 00 00 00 00
Jan 17 08:56:44.615: Incoming LSI msg: profile_id = 1, session_state = 0, pdp_c0
Jan 17 08:56:44.615: TTY3: Async Int reset: Dropping DTR
Jan 17 08:56:44.615: ip address for profile id 1
8AAC3890: 000000 0000
Jan 17 08:56:44.615: Cellular0 DirectIP: Remove negotiated IP interface address
Jan 17 08:56:44.619: Cellular0 DirectIP: Primary DNS address 193.41.63.161 remod
Jan 17 08:56:44.619: Cellular0 DirectIP: Secondary DNS 193.41.63.162 removed
Jan 17 08:56:45.543: TTY3: DSR was dropped
Jan 17 08:56:45.543: tty3: Modem: READY->(unknown)
Jan 17 08:56:46.543: TTY3: dropping DTR, hanging up
Jan 17 08:56:46.543: tty3: Modem: HANGUP->(unknown)
Jan 17 08:56:46.615: %LINK-5-CHANGED: Interface Cellular0, changed state to rest
Jan 17 08:56:47.543: TTY3: cleanup pending. Delaying DTR
Jan 17 08:56:47.615: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0,n
Jan 17 08:56:48.543: TTY3: cleanup pending. Delaying DTR
Jan 17 08:56:49.491: Setting Active SIM to 1
Jan 17 08:56:49.491: To Activate SIM powering ON the modem
Jan 17 08:56:49.491: %CISCO800-6-SIM_ACTIVATION: SIM in slot 1 is being activat.
Jan 17 08:56:50.491: Started ACQ TIMER since activate SIM
Jan 17 08:56:50.491: TTY0: resume timer type 1 (OK)
Jan 17 08:56:50.503: TTY3: cleanup pending. Delaying DTR
Jan 17 08:56:50.503: %CISCO800-2-MODEM_DOWN: Cellular0 modem is now DOWN.
Jan 17 08:56:51.503: TTY3: cleanup pending. Delaying DTR
Jan 17 08:56:52.503: TTY3: cleanup pending. Delaying DTR
Jan 17 08:56:53.471: TTY3: Async Int reset: Dropping DTR
Jan 17 08:56:53.503: TTY3: cleanup pending. Delaying DTR
Jan 17 08:56:54.503: TTY3: cleanup pending. Delaying DTR
Jan 17 08:56:55.503: TTY3: cleanup pending. Delaying DTR
Jan 17 08:56:56.503: TTY3: cleanup pending. Delaying DTR
Jan 17 08:56:57.503: TTY3: cleanup pending. Delaying DTR
Jan 17 08:56:58.471: TTY3: no timer type 0 to destroy
Jan 17 08:56:58.471: TTY3: no timer type 1 to destroy
Jan 17 08:56:58.471: TTY3: no timer type 3 to destroy
Jan 17 08:56:58.471: TTY3: no timer type 4 to destroy
Jan 17 08:56:58.471: TTY3: no timer type 10 to destroy
Jan 17 08:56:58.471: TTY3: no timer type 2 to destroy
Jan 17 08:56:58.471: Cellular0: allowing modem_process to continue hangup
Jan 17 08:56:58.471: Started ACQ Timer since Service is Not Normal
for act_sim 1 alt_sim 0
Jan 17 08:56:58.471: Sending default profile to 2 active_sim 1
Jan 17 08:56:58.523: TTY3: restoring DTR
Jan 17 08:56:58.523: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, cn
Jan 17 08:56:58.587: Received CNS_GSM_SYSTEM_STATUS: status=1
Jan 17 08:56:58.627: Received CNS_GSM_RETURN_SIM_STATUS: status=0
Jan 17 08:56:58.763: %CISCO800-2-MODEM_UP: Cellular0 modem is now UP.
sf.tb29#[Cellular0]:CALLCTRL TX MDM Data Link Sync Indication[Cellular0]:CALLCTn
Jan 17 08:56:58.827: Received CNS_GSM_SYSTEM_STATUS: status=1
Jan 17 08:56:59.071: Received CNS_GSM_SYSTEM_STATUS: status=1
Jan 17 08:56:59.091: Received CNS_GSM_SYSTEM_STATUS: status=1
Jan 17 08:56:59.111: Received CNS_GSM_SYSTEM_STATUS: status=1
Jan 17 08:56:59.123: Received CNS_GSM_RETURN_SIM_STATUS: status=0
Jan 17 08:56:59.143: Received CNS_GSM_SYSTEM_STATUS: status=1
Jan 17 08:56:59.163: Received CNS_GSM_SYSTEM_STATUS: status=0
Jan 17 08:56:59.163: Recv CW_SERVICE_STATUS_NORMAL so stopping Acquisition Timer
Jan 17 08:56:59.195: Received CNS_GSM_SYSTEM_STATUS: status=0
Jan 17 08:56:59.591: [Cellular0]:CALLCTRL RX Restart Indication (84 bytes):
00 54 62 00 54 31 5F 30 5F 33 5F 32 41 50 20 52
33 36 31 20 43 4E 53 5A 58 44 30 30 30 30 30 30
36 31 20 32 30 31 31 2F 30 34 2F 31 35 20 31 37
3A 34 30 3A 34 38 00 00 00 00 00 00 00 00 00 00
00 00 00 00
Jan 17 08:56:59.603: DIP interface Cellular0 is up!
Jan 17 08:57:00.475: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
Jan 17 08:57:01.615: Ce0 DDR: re-enable timeout
Jan 17 08:57:03.319: Received CNS_GSM_SYSTEM_STATUS: status=0
Jan 17 08:57:08.575: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel1, cp
Jan 17 08:57:10.959: CHAT3: Asserting DTR
Jan 17 08:57:10.959: CHAT3: Sending string: at+cimi
Jan 17 08:57:10.975: Received CNS_GSM_RETURN_SIM_STATUS: status=0
.Jan 17 09:03:59.609: TTY8: timer type 1 expired
.Jan 17 09:03:59.609: TTY8: Error setting disconnect cause
.Jan 17 09:03:59.609: TTY8: Exec-timeout expired
.Jan 17 09:03:59.609: TTY8: destroy timer type 1
.Jan 17 09:03:59.609: TTY9: timer type 1 expired
.Jan 17 09:03:59.609: TTY9: Error setting disconnect cause
.Jan 17 09:03:59.609: TTY9: Exec-timeout expired
.Jan 17 09:03:59.609: TTY9: destroy timer type 1
.Jan 17 09:03:59.609: TTY10: timer type 1 expired
.Jan 17 09:03:59.609: TTY10: Error setting disconnect cause
.Jan 17 09:03:59.609: TTY10: Exec-timeout expired
.Jan 17 09:03:59.609: TTY10: destroy timer type 1
.Jan 17 09:03:59.609: TTY11: timer type 1 expired
.Jan 17 09:03:59.609: TTY11: Error setting disconnect cause
.Jan 17 09:03:59.609: TTY11: Exec-timeout expired
.Jan 17 09:03:59.609: TTY11: destroy timer type 1
.Jan 17 09:03:59.609: TTY12: timer type 1 expired
.Jan 17 09:03:59.609: TTY12: Error setting disconnect cause
.Jan 17 09:03:59.609: TTY12: Exec-timeout expired
.Jan 17 09:03:59.609: TTY12: destroy timer type 1
.Jan 17 09:53:54.394: Ce0 DDR: place call
.Jan 17 09:53:54.394: Ce0 DDR: Dialing cause ip (s=10.0.248.186, d=10.0.248.185)
.Jan 17 09:53:54.394: Ce0 DDR: Attempting to dial hspa-R7
.Jan 17 09:53:54.394: CHAT3: Attempting async line dialer script
.Jan 17 09:53:54.394: CHAT3: Dialing using Modem script: hspa-R7 & System scripe
.Jan 17 09:53:54.394: CHAT3: process started
.Jan 17 09:53:54.394: CHAT3: Asserting DTR
.Jan 17 09:53:54.394: CHAT3: Chat script hspa-R7 started
.Jan 17 09:53:54.394: CHAT3: Sending string: AT!SCACT=1,1
.Jan 17 09:53:54.394: CHAT3: Expecting string: OK
.Jan 17 09:53:55.242: Received CNS_GSM_SYSTEM_STATUS: status=0
.Jan 17 09:53:55.262: [Cellular0]:CALLCTRL RX Link Status Indication (218 bytes:
00 00 04 4C 49 4E 4B 20 55 50 00 00 00 00 00 00
00 00 00 00 00 04 0A 9A 26 9D 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 04 C1 29
3F A1 00 00 00 00 00 00 00 00 00 00 00 00 04 C1
29 3F A2 00 00 00 00 00 00 00 00 00 00 00 00 00
.Jan 17 09:53:55.266: Incoming LSI msg: profile_id = 1, session_state = 4, pdp_0
.Jan 17 09:53:55.266: ip address for profile id 1
8AAC3890: 0A9A26 9D00
.Jan 17 09:53:55.270: Cellular0 DirectIP: Primary DNS address 193.41.63.161 addd
.Jan 17 09:53:55.270: Cellular0 DirectIP: Secondary DNS 193.41.63.162 added
.Jan 17 09:53:55.270: CHAT3: Completed match for expect: OK
.Jan 17 09:53:55.270: CHAT3: Chat script hspa-R7 finished, status = Success
.Jan 17 09:53:55.270: TTY3: no timer type 1 to destroy
.Jan 17 09:53:55.270: TTY3: no timer type 0 to destroy
.Jan 17 09:53:55.270: TTY3: no timer type 2 to destroy
.Jan 17 09:53:57.270: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
.Jan 17 09:53:57.270: Ce0 DDR: Dialer statechange to up
.Jan 17 09:53:57.270: Ce0 DDR: Dialer call has been placed
.Jan 17 09:53:57.270: Cellular0 DirectIP: Install negotiated IP interface addre7
.Jan 17 09:53:57.270: Ce0 DDR: dialer protocol up
.Jan 17 09:53:58.270: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0p
.Jan 17 09:54:04.394: DDR: IP Address is (10.154.38.157) for (Ce0)
