C887VAM VDSL Controller VDSL 0 is DOWN always
ITVC
I have two C887VAM-K9 routers same firmware "c887VAM-universalk9-mz.SPA.153-3.M3.bin" same configuration but 1 does not connect and I think the problem is the VDSL controller which I present the screenshots, I also tried to upgrade the controller firmware, but does not accept any files.
Thank you
Router#sh control vDSL 0
Daemon Status: Boot Init
DSL modem is not yet initialized.
Firmware Source File Name (version)
OS FW embedded VDSL_LINUX_DEV_01212008 (1)
Training Log : Stopped
Training Log Filename : flash:vdsllog.bin
%VDSL_DAEMON-3-INITFAIL: VDSL Daemon Boot init retries done max times init failed.
13 Replies 13
what is the ooperating mode of the controller ? Make sure it is set to 'auto':
Router#configure terminal
Router(config)#controller vdsl 0
Router(config-controller)#operating-mode auto
Router(config-controller)#end
Router#write memory
Also, who is your ISP ? Post the full configuration of the router that does not connect...
Hi George,
yes the controller is set to "auto"
thanks
Sorry " Georg "
which modem firmware do you have ? Post the output of:
show flash
Router#sh flash
-#- --length-- -----date/time------ path
1 68176296 Jul 28 2017 11:54:38 +00:00 c887VAM-universalk9-mz.SPA.153-3.M3.bin
2 2798822 Jun 6 2028 04:55:44 +00:00 VA_A_38k1_B_38h_24g1.bin
3 2823524 May 30 2028 00:28:48 +00:00 VA_A_39m_B_38h3_24h_o.bin
4 2798822 Jun 6 2028 02:54:38 +00:00 vdsl.bin
184086528 bytes available (76607488 bytes used)
Router#
*Dec 15 16:03:37.166: %VDSL_DAEMON-3-INITFAIL: VDSL Daemon Boot init retries done max times init failed.
delete this file from flash (back it up first, just in case you need it again), then reboot the router:
done, but the situation does not change
I inform you that the CD LED flashes very slow
in addition you must know that :
Router#sh flash
--> 2 2798822 Jun 6 2028 04:55:44 +00:00 VA_A_38k1_B_38h_24g1.bin
--> 4 2798822 Jun 6 2028 02:54:38 +00:00 vdsl.bin
--> This files is the same, i rename to vdsl.bin
thank you, there is hope
post the full output of 'show controller vdsl 0', not just snippets. We need to find out which .bin file is being used.
Also, who is your ISP, what country are you in ?
Router#show controller vdsl 0
Daemon Status: Start
Router#
My ISP --> WIND
My country --> Italy
make sure there are only two files in flash:
Router#sh flash
Also, post the full configuration of your router...
hI,
-make sure there are only two files in flash:
YES
Also, post the full configuration of your router... :
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip dhcp excluded-address X.X.X.X
ip dhcp pool DHCP-POOL
import all
network X.X.X.X 255.255.255.0
default-router X.X.X.X
dns-server X.X.X.X
domain-name XXXXXXX.XXX
ip cef
no ipv6 cef
license udi pid C887VAM-K9 sn XXXXXXXXXXX
controller VDSL 0
firmware filename flash:VA_A_38k1_B_38h_24g1.bin
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
no atm ilmi-keepalive
no snmp trap link-status
interface Ethernet0
no ip address
interface Ethernet0.835
encapsulation dot1Q 835
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address X.X.X.X 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Dialer0
description WAN WIND
ip address negotiated
ip access-group 100 in
ip access-group 100 out
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname XXX
ppp chap password 0 XXX
ppp pap sent-username XXX password 0 XXX
ppp ipcp dns request
ppp ipcp route default
ppp ipcp address accept
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list aclAllowNat interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended aclAllowNat
remark --- Traffic allowed to be NATed from inside to out.
remark --- Block NAT traffic to RFC1918 addresses verbosely
deny ip any 10.0.0.0 0.255.255.255
deny ip any 172.16.0.0 0.15.255.255
deny ip any 192.168.0.0 0.0.255.255
permit ip X.X.X.X 0.0.0.255 any
dialer-list 1 protocol ip permit
access-list 100 deny tcp any any eq telnet
access-list 100 permit ip any any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
there is something wrong at Layer 1. I have made some changes to your config (marked in bold), try and implement those:
version 15.3
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
import all
dns-server X.X.X.X
ip cef
no ipv6 cef
controller VDSL 0
--> no firmware filename flash:VA_A_38k1_B_38h_24g1.bin
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
--> no shutdown
interface ATM0.1 point-to-point
description WAN Interface
pvc 8/35
interface Ethernet0
no ip address
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip nat inside
interface Dialer0
ip mtu 1452
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
--> no ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
no ip http server
ip dns server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
end
Hi Georg,
I've applied the recommended changes, but nothing changes, the vDSL controller seems to be stuck.
CD LED always flashes slowly in the same way.
The full listing of:
Router#sh ip int br
ATM0 unassigned YES NVRAM initializing down
ATM0.1 unassigned YES unset initializing down
Dialer0 unassigned YES NVRAM up up
Ethernet0 unassigned YES NVRAM up down
Ethernet0.835 unassigned YES unset up down
FastEthernet0 unassigned YES unset up up
FastEthernet1 unassigned YES unset up down
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset up down
NVI0 unassigned YES unset administratively down down
Virtual-Access1 unassigned YES unset up up
Vlan1 X.X.X.X YES NVRAM up up
Please note that I have an equal same router configured in the same way:
It connects always good.
Thank you
