How to subnet BGP advertised IP
man3mar3n
I have the below config which the peering works with the ISP. However, I need to subnet the IP to be distributed to all my customers like A.A.A.0/29 OR A.A.A.8/29.
If I change the Gi0/1 IP address to A.A.A.1 255.255.255.248, the bgp fails.
How can I subnet the IPs. I have a full class C IP (A.A.A.0/24) to distribute.
interface GigabitEthernet0/0
 description WAN Interface
 ip address C.C.C.134 255.255.255.252
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description LAN Interface
 ip address A.A.A.1 255.255.255.0
 duplex auto
 speed auto
router bgp MYAS-NUM
 bgp router-id X.3
 bgp log-neighbor-changes
 neighbor C.C.C.133 remote-as BBBBB
 neighbor C.C.C.133 description --- eBGP Uplink ---
 address-family ipv4
  no synchronization
  bgp dampening
  network A.A.A.0 mask 255.255.255.0
  redistribute connected
  redistribute static
  neighbor C.C.C.133 activate
  neighbor C.C.C.133 next-hop-self
  neighbor C.C.C.133 remove-private-as
  neighbor C.C.C.133 soft-reconfiguration inbound
  neighbor C.C.C.133 prefix-list PL-ISP out
  no auto-summary
 exit-address-family
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip prefix-list PL-ISP seq 12 permit A.A.A.0/24
ip prefix-list PL-ISP seq 20 deny 0.0.0.0/0 le 32
Please help.
Thanks.
Hi, try to add this static route:
ip route A.A.A.0 255.255.255.0 Null0
In this way all the subnet/24 will be announced but test is before to use this config in standby.
Regards.
18 Replies 18
Regards.
Hello
 duplex auto
 speed auto
 duplex auto
 speed auto
router bgp MYAS-NUM
 bgp router-id X.3
 address-family ipv4
  no synchronization
  bgp dampening
  redistribute static
  no auto-summary
 exit-address-family
Please
Hello
when you say bgp fails I am assuming you mean the lan subnet fails to be advertised?
The reason for this your changing the lan interface ip address to a /29 subnet but your not advertising that in your prefix-list or via  bgp network command.
Try adding this before you changing the lan interface ip address.
router bgp xxx
network 192.168.1.0 mask 255.255.255.248
exit
ip prefix-list PL-ISP seq 15 permit A.A.A.0/29
On a side note as your filtering outbound route advertisements, There really isn't any need for the redistribute static or connected commands
Also due route-refresh in bgp you dont need to use soft-reconfiguration either.
router bgp xx
no redistribute connected
no redistribute static
no neighbor C.C.C.133 soft-reconfiguration inbound
Kind Regards
Paul
I believe that we need some clarification from the original poster. My understanding of the original post is that they have a complete class C network and that they want to subdivide (subnet) it so that various of their customers can use parts of it. If my understanding is correct then advertising the complete /24 to the ISP (which I assume is the BGP neighbor) is appropriate. If my understanding is not correct then please clarify what is the situation.
Advertising a /29 to an ISP generally does not work since many ISP will not advertise anything smaller than a /24.
If my understanding is correct then the BGP to the ISP is ok and we need to look at how they communicate with and route to their customers who are using parts of this network.
Rick
Rick
Hi Rick,
You are right. I cannot advertise anything smaller than /24.
So I advertise the complete /24 segment. My actual segment is /22.
However, I have a few customer that will be using this range and I need to subnet it with different gateway.
I am stuck because it does not allow me to subnet it.
I also have a /48 subnet of IPv6 and thinking to advertise part of it /50.
Please advice.
As Daniele indicated, you need to configure a static route (to null0) for the /24 you want to advertise or better the /22 that you own and have a matching network statement under the BGP configuration. You will then be able to subnet this as you will internally.
The same approach does not seems to be working for ipv6.
For IPv4, i have /22 but choose to advertise /24 only. It allows the subnetting.
When I do a route to null0, it allows for further breaking of the segment to /29 or /28.
However, for IPv6, I have a /48 segment and I choose to advertise only /50.
The same approach doesn't seems to be working.
router bgp myas-NUM
 bgp router-id rid.3
 neighbor B:B:B::29 remote-as RMAS-NUM
 neighbor B:B:B::29 description --- eBGP Uplink ---
 address-family ipv6
  network A:A:A:C000::/50
  neighbor B:B:B::29 activate
  neighbor B:B:B::29 next-hop-self
  neighbor B:B:B::29 remove-private-as
  neighbor B:B:B::29 prefix-list PL-ISP out
 exit-address-family
ipv6 route ::/0 B:B:B::29
ipv6 prefix-list PL-ISP seq 10 permit A:A:A:C000::/50 le 64
Please help.
The advertisement looks normal but it is not working
sh bgp ipv6 uni nei B:B:B::29 ad
BGP table version is 9, local router ID is rid.3
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> A:A:A:C000::/50
                    ::                       0         32768 i
Total number of prefixes 1
Please define "not working". Is it not being installed in the RIB of the bgp neighbor router? Do you see it in BGP?
I do not see the ipv6 static route to null0 for the specific /50. Did you configure it. Bear in mind that the rule for the network statement is that it need a matching route in the RIB to be effective.
even with the route to null0, the bgp not working
router bgp myas-NUM
 bgp router-id rid.3
 address-family ipv6
 exit-address-family
ipv6 route A:A:A:c000::/50 Null0
I have the interface IP as follows
 ipv6 address A:A:A:C000::1/64 (even A:A:A:C000::1/50 not working)
 ipv6 enable
Am I correct in understanding that your issue with the IPv4 addresses is resolved and that you can do what you need to do with these addresses and that your remaining issue is with the IPv6 addresses?
Rick
Rick
I could change the Interface IP to A.A.A.1/29 after I put in the route to null0.
The BGP works and I could ping the Interface from Internet.
I need to subnet it further for our customer use.
I will do this tonight.
However, the same config applied to IPv6 does not work though it advertisement look correct.
What do you mean by "it is not working"? From the following output, it certainly looks like the /50 is being advertised.
*> A:A:A:C000::/50
                    ::                       0         32768 i
Even though the advertisement looks right, I don't see the advertised subnet when I query it from BGP Lookup table.
I also could not ping the interface from Internet and a PC connected to this segment has no Internet access.
ip address B.B.B.134 255.255.255.252
duplex auto
speed auto
ipv6 address BB:BB:BB::2A/126
ipv6 enable
ip address A.A.A.1 255.255.255.248
duplex auto
speed auto
ipv6 address AA:AA:AA:C000::1/64
ipv6 enable
router bgp MY-AS-NUM
bgp router-id RID.3
neighbor BB:BB:BB::29 remote-as REM-AS-NUM
neighbor BB:BB:BB::29 description --- IPv6 eBGP Uplink ---
neighbor B.B.B.133 remote-as REM-AS-NUM
neighbor B.B.B.133 description --- IPv4 eBGP Uplink ---
address-family ipv4
no synchronization
bgp dampening
network A.A.A.0 mask 255.255.255.0 ( I advertised /24 from /22 i have)
neighbor BB:BB:BB::29 activate
neighbor B.B.B.133 activate
neighbor B.B.B.133 next-hop-self
neighbor B.B.B.133 remove-private-as
neighbor B.B.B.133 prefix-list PL-ISP out
no auto-summary
exit-address-family
address-family ipv6
network AA:AA:AA:C000::/50 ( I advertised /50 from /48 i have)
neighbor BB:BB:BB::29 next-hop-self
neighbor BB:BB:BB::29 remove-private-as
neighbor BB:BB:BB::29 prefix-list PL-ISP-V6 out
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route A.A.A.0 255.255.255.0 Null0 (without this - I loss internet access for my LAN)
ip route A.A.A.8 255.255.255.248 A.A.A.2 (I segment it for customer A - not sure if this works)
ip route A.A.A.16 255.255.255.240 A.A.A.2 (I segment it for customer B - not sure if this works)
ip prefix-list PL-ISP seq 18 permit A.A.A.0/24
ipv6 route AA:AA:AA:C000::/50 Null0
ipv6 route ::/0 BB:BB:BB::29
ipv6 prefix-list PL-ISP-V6 seq 10 permit AA:AA:AA:C000::/50 le 64
