C891F default memory size
ValeriiaZ
Hello, all.
Are anybody know, how many RAM has C891F by default?
Here I have found, that it has 1Gb fixed and not extendable RAM by default
http://www.cisco.com/c/en/us/td/docs/routers/access/800/hardware/installation/guide/800HIG.pdf
but here is written, that it has 512Mb and the memory size can be upgradeble to 1Gb with FL-8XX-512U1GB license
http://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/data_sheet_c78-519930.html
Where is the right information?
If 512Mb is the right answer, does it mean, that 1Gb is physicaly installed, but only 512Mb is used without upgrade license?
Thanks in advance.
0 Replies 0
