C891F WAN INTERFACES - DUAL WAN
JasonHFujitsu
A client has purchased a C891F router to replace an existing router that uses 2 WAN connections to establish a Site to Site VPN over each WAN respectively (2 Total).
While working with Cisco Configuration Professsional, I noted that the ports do not have the same options (FastEthernet 0 as Gigabit Ethernet8)
Can you please indicate which interfaces should be used to configure WAN connections that would then be used to establish IPSEC VPN’s?
As the router will be programmed and then shipped for installation, I would like to ensure that everything is fine!
Thank you!
0 Replies 0
