C892, 15.3(3)M5, QoS Allowed CIR range
Hi I'm trying to apply the following QoS config:
policy-map PM-L2-OUT
description LEVEL2 Out Policy
class CM-NET-CONTROL
bandwidth percent 20
set mpls experimental topmost 6
class CM-QG3
set mpls experimental topmost 3
class CM-QG1
bandwidth percent 50
set mpls experimental topmost 1
class class-default
random-detect
queue-limit 300 ms
set mpls experimental topmost 0
policy-map PM-CORE-L1-OUT
description LEVEL1 Out Policy
class CM-QG5
priority level 2
police rate percent 10
set mpls experimental topmost 5
class class-default
service-policy PM-L2-OUT
shape average percent 100
interface GigabitEthernet0
bandwidth 200000
When I try to apply the service policy to Gig0 the router complains:
router1(config-if)#service-policy output PM-CORE-L1-OUT
Configured Percent results in CIR out of range. Allowed CIR range is 1000-154400000.
The present CIR value is 200000000
It looks a bit like the max-reserved-bandwith thing, however that does not exist anymore in IOS 15.3. I tried it with real bandwith values in the policy-map, no success either. Is there a numeric upper limit for a shaper, is this box dependent, or is there another possibility to get this running? I have not found any clear explanation or even better a solution to my problem.
12 Replies 12
post the full config.
class CM-QG5
does not exist in the partial config you posted...
Hi Georg
I basically match to QoS-groups (QG...) that were set on the input interfaces with matching of PHBs. But that does not really add valuable information to the question I have. I asked for the shaper, not for the marker. And to keep the output short I omitted the class-maps.
Kind regards
Mat
the reason I am asking for the full configuration is so I can lab this with different IOS versions and on different platforms. I want to see if it is IOS and/or platform related.
You can post the full config and take out any sensitive information such as public IP addresses and username/passwords, etc.
either way, I entered your config in 15.6(2)T, and got no errors. The 'show policy-map output is below, can you post the equivalent of your output ?
Router#sh policy-map
Policy Map PM-L2-OUT
Class CM-NET-CONTROL
bandwidth 20 (%)
Class CM-QG1
bandwidth 50 (%)
Class CM-QG3
bandwidth 20 (%)
Class class-default
msec wred, exponential weight 9
class min-threshold max-threshold mark-probablity
0 - - 1/10
1 - - 1/10
2 - - 1/10
3 - - 1/10
4 - - 1/10
5 - - 1/10
6 - - 1/10
7 - - 1/10
queue-limit 300 ms
Policy Map PM-CORE-L1-OUT
Class CM-QG5
priority level 2
conform-action transmit
exceed-action drop
Class class-default
Average Rate Traffic Shaping
cir 100%
Router#
the error only pops up when I try to apply the policy-map to a Gig Interface with a configured BW of 200000 kbps. The policy map as such works perfectly for scenarios with lower bandwidths.
Here's the config including the class-maps:
class-map match-any CM-NET-CONTROL
description matches Routing Protocols, BFD and LDP
match dscp cs6
match mpls experimental topmost 6
match qos-group 6
class-map match-any CM-QG5
match qos-group 5
class-map match-any CM-QG3
match qos-group 3
class-map match-any CM-QG1
match qos-group 1
class CM-QG3
class CM-QG1
class class-default
random-detect
queue-limit 300 ms
class CM-QG5
priority level 2
class class-default
bandwidth 200000
Hello
Instead of BW percent try accommodating whats is available on the Bw
bandwidth remaining percent 20
class CM-QG3
class CM-QG1
bandwidth remaining percent 50
Kind Regards
Paul
As I said in an answer before the policy-map works fine with lower bandwidths. It's the shaper that seems to cause the issue. I have set up a policy-map with only a shaper and get the same error:
policy-map PM-TEST
 class class-default
 bandwidth 200000
 service-policy output PM-TEST
-> Configured Percent results in CIR out of range. Allowed CIR range is 1000-154400000.
The actual CIR value and the allowed CIR range look like 100%/75%. So that's why I think it might have something in common with the 75% rule (max-reserved-bandwidth). But I have not found any documentation that gives me details on my situation.
Hello
It does seem to suggest this is the case - 0.25 x200000 =150000
One way to check would to look at the queueing on the interface and possibly change the default
show queueing interface x/x | Av
int x/x
max-reserved-bandwidth 90
end
Also suggest aply some fair queueing to the class class default
class class-default
fair-queue
Kind Regards
Paul
Paul
As I said before the max-reserved-bandwidth command has been deprecated since IOS 15.0 or 15.1. So no possibility to use that one. The fair-queue is a good hint, I'm sure that I had it in a previous version, I have to check why I removed it.
Kind regards
Mat
I wonder if it is platform related, the 892 throughput is relatively low. What if you set the bandwidth to 275000 ? If it is related to the max reserved bandwidth, the error shouldn't appear...
Cool idea, however it seems to be hardware related:
router(config)#int g0
router(config-if)#band 266666
router(config-if)#service-policy output PM-TEST
The present CIR value is 266666000
I think it is a hardware limitation. On the 800 series, you can shape the average to a maximum value of 154400000
800(config-pmap-c)#shape average ?
<8000-154400000>
On a higher end router, the limit is1000000000:
Router(config-pmap-c)#shape average ?
<1000-1000000000>
