Static reservation in Router DHCP pool
dastrix80
Hi All,
So im aware you create a new pool, lets say 'STATIC' which has the client-identifier (mac address) of the host. you also specify the ip you want, with ip host <insert ip mask>
This however fails for me. The client is unreachable.
When I delete the pool and use DHCP, the client works fine.
Any thoughts?  Cisco 3945 running 15.2
ip dhcp pool LAN
 network 192.168.0.0 255.255.255.0
 dns-server 192.168.0.254 202.142.142.142
 default-router 192.168.0.254
 lease infinite
ip dhcp pool STATIC
 host 192.168.0.141 255.255.255.0
 client-identifier 1cca.e371.06fd
Even appending 01 for ethernet makes no difference
ip dhcp pool STATIC
 client-identifier 011c.cae3.7106.fd
11 Replies 11
Dennis Mink
can you run debug dhcp detail and debug dhcp server events on the router and verify that the client identifier you have configured is actually the one that the end station uses for dhcp.
Please remember to rate useful posts, by clicking on the stars below.
HI Dennis, ive ran those debugs and when the second pool is setup for STATIC, i see nothing from this host.
The host works fine whe using DHCP from the normal pool
Internet 192.168.0.22 32 6c94.f8ea.b6d4 ARPA Vlan1
Internet 192.168.0.23 0 1cca.e371.06fd ARPA Vlan1
3945-KK#ping 192.168.0.23
Sending 5, 100-byte ICMP Echos to 192.168.0.23, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
3945-KK#
Try removing the "default-router" command from under the STATIC pool. This is already inherited.
Please remember to rate useful posts, by clicking on the star below.
-Troy J.
I tried this also.
I think i have hardware issue with the device connected, the port is showing up but theres no mac learnt. It was pingable before also.. It goes up and down :/
run wireshark on the connecting end point and see if it is getting anything back, dhcp related from the router
Hello
How are you testing this, I mean what client are you using, Is it in a virtula lab like gns3?
Set the client interfce so to tell dhcp to use he mac address of the client and any switchport its connect to.
int x/x
ip address dhcp client-id x/x
In any case you be able to see what mac address is being used  for dhcp in a debug
Debug dhcp det
Kind Regards
Paul
Hi Paul
its a intercom from a company called Doorbird and I think its faulty so hold fire on further troubleshooting
Cheers
Kris
Hi Paul
I dont understand these commands. I have a device on the LAN, ona 3560E. Do these go on the VLAN1 of the router??
Cheers
Hello
As I suggestion that command if you were only lab testing within a simualter like GNS3 or had a routed interface you needed to obtain a dhcp allowcation. not a physcal bespoke client.
Are you still experiencing this issue? - if so have you applied a debug on the router/switch to see what is happenng or maybe a wireshark capture from the client itself?
Kind Regards
Paul
Hi Paul;
Using hardware address I got it working today for one of my clients! Ill try the other one tomorrow
This is my home network
Cheers
