C9500 Stackwise-virtual failover BGP downtime
ms339r001
we have deployed pair of 9500-32C in Stacwise-virtual. It is Aggregation node of big site and connecting to backbone by 2 EBGP links (one from each switch).
I have noticed long downtime during ISSU and as we are deploying more of these to other sites prepared lab as per drawing bellow.
Running on cat9k_iosxe.17.09.04a.SPA.bin which was suggested release at the time.
Now I'm testing the convergence during force-switchover, which part of ISSU process.
In following test run the switch 1 was master (ebgp neighbor 10.0.0.1 is connected to it) and switch 2 is standby (connecting ebgp 10.0.0.3).
EBGP is configured to redistribute connected networks, which for test is Loopback and Vlan100 192.168.100.0/0 with test5 switch SVI at address 192.168.100.100. Before failover both test3 and test4 can reach test5.
[2024-04-15 16:09:19] test1#show bgp summary
[2024-04-15 16:09:20] <shortened>
[2024-04-15 16:09:20] Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
[2024-04-15 16:09:20] 10.0.0.1        4        65002      29      30        8    0    0 00:22:06        5
[2024-04-15 16:09:20] 10.0.0.3        4        65002      29      30        8    0    0 00:21:17        5
[2024-04-15 16:09:34] test1#show bgp ipv4 unicast neighbors 10.0.0.1 advertised-routes
[2024-04-15 16:09:34] <shortened>
[2024-04-15 16:09:34]      Network          Next Hop            Metric LocPrf Weight Path
[2024-04-15 16:09:34]  *>   10.0.0.0/31      0.0.0.0                  0         32768 ?
[2024-04-15 16:09:34]  *>   10.0.0.2/31      0.0.0.0                  0         32768 ?
[2024-04-15 16:09:34]  *>   10.0.1.0/31      10.0.0.1                 0             0 65002 ?
[2024-04-15 16:09:35]  *>   192.168.1.1/32   0.0.0.0                  0         32768 ?
[2024-04-15 16:09:35]  *>   192.168.1.3/32   10.0.0.1                 0             0 65002 ?
[2024-04-15 16:09:35]  *>   192.168.1.4/32   10.0.0.1                               0 65002 ?
[2024-04-15 16:09:35]  *>   192.168.100.0    0.0.0.0                  0         32768 ?
[2024-04-15 16:09:35] Total number of prefixes 7
[2024-04-15 16:09:35] test1#show bgp ipv4 unicast neighbors 10.0.0.3 advertised-routes
[2024-04-15 16:09:42] BGP table version is 8, local router ID is 192.168.1.1
[2024-04-15 16:09:42] Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
[2024-04-15 16:09:42]               r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
[2024-04-15 16:09:42]               x best-external, a additional-path, c RIB-compressed,
[2024-04-15 16:09:43]               t secondary path, L long-lived-stale,
[2024-04-15 16:09:43] Origin codes: i - IGP, e - EGP, ? - incomplete
[2024-04-15 16:09:43] RPKI validation codes: V valid, I invalid, N Not found
[2024-04-15 16:09:43]      Network          Next Hop            Metric LocPrf Weight Path
[2024-04-15 16:09:43]  *>   10.0.0.0/31      0.0.0.0                  0         32768 ?
[2024-04-15 16:09:43]  *>   10.0.0.2/31      0.0.0.0                  0         32768 ?
[2024-04-15 16:09:43]  *>   10.0.1.0/31      10.0.0.1                 0             0 65002 ?
[2024-04-15 16:09:43]  *>   192.168.1.1/32   0.0.0.0                  0         32768 ?
[2024-04-15 16:09:43]  *>   192.168.1.3/32   10.0.0.1                 0             0 65002 ?
[2024-04-15 16:09:43]  *>   192.168.1.4/32   10.0.0.1                               0 65002 ?
[2024-04-15 16:09:43]  *>   192.168.100.0    0.0.0.0                  0         32768 ?
[2024-04-15 16:09:43] Total number of prefixes 7
Then I performed failover and moved console cable to switch2 in SWV:
[2024-04-15 16:10:17] test1#redundancy force-switchover
[2024-04-15 16:10:19] Proceed with switchover to standby RP? [confirm]
[2024-04-15 16:10:23]     Manual Swact = enabled
[2024-04-15 16:10:25]
[2024-04-15 16:10:25] *Apr 15 14:11:07.667: %REDUNDANCY-3-SWITCHOVER: RP switchover (PEER_NOT_PRESENT)
[2024-04-15 16:10:25] *Apr 15 14:11:07.668: %REDUNDANCY-3-SWITCHOVER: RP switchover (PEER_DOWN)
[2024-04-15 16:10:25] *Apr 15 14:11:07.668: %REDUNDANCY-3-SWITCHOVER: RP switchover (PEER_REDUNDANCY_STATE_CHANGE)
[2024-04-15 16:10:41] *Apr 15 14:11:14.842: %BGP-5-ADJCHANGE: neighbor 10.0.0.3 Up show bgp summary
[2024-04-15 16:10:44] <shortened>
[2024-04-15 16:10:44] Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
[2024-04-15 16:10:44] 10.0.0.1        4        65002       0       0        1    0    0 never    Idle
[2024-04-15 16:10:44] 10.0.0.3        4        65002       6       2        1    0    0 00:00:11        4
After failover BGP connection is reset, but seem to be reestablished immediately. The part which according to my testing causing long outage is that test1 don't advertise connected network for almost 90 seconds.
[2024-04-15 16:10:47] test1>show bgp ipv4 unicast neighbors 10.0.0.3 advertised-routes
[2024-04-15 16:10:51]
[2024-04-15 16:10:51] Total number of prefixes 0
[2024-04-15 16:11:02] Total number of prefixes 0
[2024-04-15 16:11:02] test1>show bgp ipv4 unicast neighbors 10.0.0.3 advertised-routes
[2024-04-15 16:11:03]
[2024-04-15 16:11:03] Total number of prefixes 0
[2024-04-15 16:11:03] test1>show bgp summary | i 10.0.0.3
[2024-04-15 16:11:12] 10.0.0.3        4        65002       6       2        1    0    0 00:00:39        4
[2024-04-15 16:11:42] test1>show bgp ipv4 unicast neighbors 10.0.0.3 advertised-routes
[2024-04-15 16:11:42] BGP table version is 7, local router ID is 192.168.1.1
[2024-04-15 16:11:42] Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
[2024-04-15 16:11:43]               r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
[2024-04-15 16:11:43]               x best-external, a additional-path, c RIB-compressed,
[2024-04-15 16:11:43]               t secondary path, L long-lived-stale,
[2024-04-15 16:11:43] Origin codes: i - IGP, e - EGP, ? - incomplete
[2024-04-15 16:11:43] RPKI validation codes: V valid, I invalid, N Not found
[2024-04-15 16:11:43]      Network          Next Hop            Metric LocPrf Weight Path
[2024-04-15 16:11:43]  *>   10.0.0.2/31      0.0.0.0                  0         32768 ?
[2024-04-15 16:11:43]  *>   192.168.1.1/32   0.0.0.0                  0         32768 ?
[2024-04-15 16:11:43]  *>   192.168.100.0    0.0.0.0                  0         32768 ?
[2024-04-15 16:11:43] Total number of prefixes 3
 I have tried to play with graceful-restart timers, but what seems to be the core of my issue is long advertisement delay.
It seems inappropriate for HA solution to have such a long downtime especially with manually triggered failover.
My configuration on test1:
stack-mac persistent timer 0
boot system bootflash:packages.conf
switch 1 provision c9500-32c
switch 2 provision c9500-32c
stackwise-virtual
 domain 200
 dual-active detection pagp trust channel-group 1
redundancy
  mode sso
interface HundredGigE1/0/1
 switchport mode trunk
 channel-group 1 mode desirable
interface HundredGigE1/0/2
interface HundredGigE1/0/3
interface HundredGigE1/0/4
 stackwise-virtual link 1
interface HundredGigE1/0/32
 no switchport
 ip address 10.0.0.0 255.255.255.254
interface HundredGigE2/0/1
interface HundredGigE2/0/2
interface HundredGigE2/0/3
interface HundredGigE2/0/4
interface HundredGigE2/0/32
 no switchport
 ip address 10.0.0.2 255.255.255.254
interface Vlan1
 no ip address
interface Vlan100
 ip address 192.168.100.1 255.255.255.0
router bgp 65001
 bgp log-neighbor-changes
 bgp graceful-restart restart-time 1
 bgp graceful-restart stalepath-time 1
 neighbor 10.0.0.1 remote-as 65002
 neighbor 10.0.0.1 ha-mode graceful-restart
 neighbor 10.0.0.3 remote-as 65002
 neighbor 10.0.0.3 ha-mode graceful-restart
 address-family ipv4
  neighbor 10.0.0.1 activate
  neighbor 10.0.0.1 soft-reconfiguration inbound
  neighbor 10.0.0.3 activate
  neighbor 10.0.0.3 soft-reconfiguration inbound
 exit-address-family
test1#show issu state detail
Current ISSU Status: Enabled
Previous ISSU Operation: Successful
System Check                        Status
Platform ISSU Support               Yes
Standby Online                      Yes
Autoboot Enabled                    Yes
SSO Mode                            Yes
Install Boot                        Yes
Valid Boot Media                    Yes
Operational Mode                    HA-REMOTE
No ISSU operation is in progress
According to this presentation the failover should be in sub-seconds but that shows only L2 scenarios: https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2023/pdf/BRKENS-2095.pdf
Do I missing some configuration? Thanks
6 Replies 6
balaji.bandi
Maybe  try NSF config and test - i do not see the configuration SSO config ?
check below guide :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-8/configuration_guide/ha/b_168_ha_9500_cg.pdf
BB
Can I see both SW config, I interested in this issue and try to understand how you config it.
MHM
unless you really need redistribution, what happens if yiou just advertise your connected network ?
network 10.0.0.0 mask 255.255.255.254
network 10.0.0.2 mask 255.255.255.254
network 192.168.100.0 mask 255.255.255.0
Or you could try BFD (neighbor x.x.x.x fail-over bfd).
PAPL
I am experiencing the same issue and running the same version 17.9.4a. We have opened a TAC case with Cisco
Hello PAPL,
was TAC any helpful?
I'm about to get back to this as need to break the lab and move nodes to production and about to deploy more of these SWV pairs to production.
Michal
Can more elaborate what is issue maybe I can help you
MHM
