CAB-ASYNC-8 Cable specification
PhilS
Can anyone point me in the direction of the cable specification/pinout for the CAB-ASYNC-8 cable?
5 Replies 5
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/support/docs/dial-access/asynchronous-connections/14958-24.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi, that spec if for a legacy cable, not the smart serial CAB-ASYNC-8.
which specs are you looking for exactly ? The exact HD pinouts ?
Hi, I am looking for the Cisco Specification datasheet, yes. I usually use these as reference in customer facing docs, so using a leagcy document, for a different cable is not ideal.
bunklung1
Looking for information on the new style NIM-16A card. I do understand the pinouts are the same at the end of the cables. I am curious if the NIM-16A has the same pinout at the HWIC-16A BEFORE the breakouts cable. I am troubleshooting a DTE/DCE issue and it may explains my headaches if the NIM-16A and the HWIC-16A have flopped pinouts.
Thanks.
