Problem with nat on ipsec tunnel
Hey there! We want to create an IPsec tunnel between our office
and one of our partners and here is the topology:
OurServer<---->OurRouter<---->Internet<---->TheirRouter<---->TheirServer
Partner_Router_public_IP: 1.1.1.1
Our_Router_Public_IP: 2.2.2.2
Partner_Server: 3.3.3.3
our_server: 192.168.1.10
tunnel_OurSide: 192.168.20.2
tunnel_TheirSide: 192.168.20.1
The problem is i cannot ping partner server from our server while I am connected to internet using this
nat:
ip nat inside source list 1 interface GigabitEthernet0/2 overload
Once I remove the above line I lose internet connection from ou server but i can ping
the partner server.
can you please tell me how to write my nat setting?
version 15.1
service password-encryption
hostname office-router
boot-start-marker
boot-end-marker
enable secret 4 ******************
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip domain name office.com
username admin password 7 **************
redundancy
crypto isakmp policy 370
encr 3des
authentication pre-share
group 2
crypto isakmp key ******** address 1.1.1.1 (Partner public IP)
crypto ipsec transform-set office-TS esp-aes 256 esp-sha-hmac
mode transport
crypto ipsec profile office-PF
set transform-set office-TS
interface Tunnel4170
description connect to post
ip address 192.168.20.2 255.255.255.0 (Tunnel IP Ourside)
ip nat outside
ip virtual-reassembly in
tunnel source 2.2.2.2 (Our public IP)
tunnel destination 1.1.1.1 (Partner public IP)
tunnel protection ipsec profile office-PF
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.1.1 255.255.255.0 (Our Lan IP address)
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip address 2.2.2.2 255.255.255.0 (Our wan interface public ip address)
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/3/0
no ip address
interface GigabitEthernet0/3/1
no ip address
interface GigabitEthernet0/3/2
no ip address
interface GigabitEthernet0/3/3
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list PARTER-NAT interface Tunnel4170 overload
ip route 0.0.0.0 0.0.0.0 2.2.2.1 (Our ISP Router)
ip route 3.3.3.3 255.255.255.255 192.168.20.1 name POST (3.3.3.3 partner-server 192.168.20.1 tunnel ip partner side)
ip access-list extended PARTER-NAT
permit ip host 192.168.1.10 host 3.3.3.3 (192.168.1.10 our lan server 3.3.3.3 partnerserver)
permit ip any host 3.3.3.3 (partner-server)
permit ip 192.168.1.0 0.0.0.255 any (Our lan)
access-list 1 permit 192.168.1.0 0.0.0.255 (our lan)
control-plane
line con 0
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 ********
login local
transport input ssh
scheduler allocate 20000 1000
end
10 Replies 10
make the changes/additions marked in bold:
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
redundancy
encr 3des
group 2
mode transport
--> no ip nat outside
no ip address
shutdown
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
no ip address
no ip address
no ip address
no ip address
interface Vlan1
no ip address
no ip http server
--> no ip nat inside source list PARTER-NAT interface Tunnel4170 overload
--> ip nat inside source list 1 interface GigabitEthernet0/2 overload
--> ip route 3.3.3.3 255.255.255.255 Tunnel4170
--> no ip access-list extended PARTER-NAT
control-plane
line con 0
logging synchronous
login local
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
password 7 ********
login local
transport input ssh
end
Hi there. first, of all, I'm really sorry I was not available for days due to the covid-19 lockdown in my country. I have done your setup
but It didn't work as you can see my config after your setup below:
Building configuration...
Current configuration : 3021 bytes
! Last configuration change at 08:41:56 UTC Mon Apr 5 2021 by admin
version 15.1
hostname axon-router
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip name-server 8.8.8.8
redundancy
encr 3des
group 2
crypto isakmp key ****** address 1.1.1.1 (Partner public IP)
mode transport
no ip address
shutdown
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
no ip address
no ip address
no ip address
no ip address
interface Vlan1
no ip address
no ip http server
control-plane
line con 0
logging synchronous
login local
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
login local
transport input ssh
end
the configuration looks correct. What seems a bit odd is that you only want IP address 3.3.3.3/32 to be reachable through the tunnel. Usually, LAN to LAN traffic would be encrypted. What traffic is being matched n the other (the Partner) side, which source and destination traffic are they encrypting ?
balaji.bandi
You need to remove the NAT for the destination as exmaple :
ip access-list extended Test-NAT
deny ip 172.16.10.0 0.0.0.255 10.10.10.0 0.0.0.255
permit ip 172.16.10.0 0.0.0.255 any
172.16.10.0/24 LAN IP address
10.10.10.0/.24 - remove IP address
i
BB
Thanks For your help but It did not solve the problem, from my router I can ping 3.3.3.3
but from our LAN server: (192.168.1.10) I still cannot ping 3.3.3.3.
I am a Linux system administrator and my knowledge about cisco is very limited so sorry about that
Which post are you referring to, what did not solve the problem ? Post the configuration again with the changes I suggested...
Can post the complete config again after changing, so we know what is changed and this time i will amend the configuration for you. so it is easy to paste since you mentioned you have little knowledge of cisco.
BB
I agree that it would be helpful to see a copy of the update/current running config. I would also ask for the output of show crypto ipsec sa from the router.
The original post tells us that they can ping the remote server from the router. I wonder if part of that is due to the fact that the remote server is shown with a public IP. If the router ping is sourced from its outside interface Public IP to a destination Public IP it is possible that the fact that it is successful may not really tell us anything about the state of the vpn tunnel. On the router if you attempt ping to the server and specify the ping source as 192.168.1.1 is the ping still successful?
Rick
Hello
Why NAT on the secure tunnel?
If you need to nat then I would say this would be applied on the wan interfaces for any traffic not requiring traversing the ipsec tunnel?
Example below - but obviously amend for both sites.
no ip nat outside
int x/x
description WAN
ip nat outside
no access-list 1 permit
no ip route 3.3.3.3 255.255.255.255 192.168.20.1 name POST
ip route 3.3.3.3 255.255.255.255 tunnel 4170 192.168.20.1 name POST
Kind Regards
Paul
Thanks for the response but the problem still exists I am sorry.
