CAB-SS-530AMT Back-to-Back Connections
Anthony90
Hi Cisco Community,
I've successfully configured a back-to-back serial connection between a Cisco 4331 ISR with a NIM-2T module and a Cisco 2851 with a WIC-2T card.
They were using CAB-SS-232FC DCE and CAB-SS-232MT DTE cables.
I need to configure the same using an RS-530A cable.
However, the Cisco NIM-2T datasheet only lists a DTE cable - CAB-SS-530AMT, no DCE cables .
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/datasheet-c78-732155.html
Table 3. Smart Serial Cabling for NIM-1T, NIM-2T, and NIM-4T
Product Number
Cable Type
Length
Connector Type
CAB-SS-V35MT
V.35 DTE
10 ft (3m)
Male
CAB-SS-V35FC
V.35 DCE
10 ft (3m)
Female
CAB-SS-232MT
EIA/TIA-232 DTE
10 ft (3m)
Male
CAB-SS-232FC
EIA/TIA-232 DCE
10 ft (3m)
Female
CAB-SS-449MT
EIA/TIA-449 DTE
10 ft (3m)
Male
CAB-SS-449FC
EIA/TIA-449 DCE
10 ft (3m)
Female
CAB-SS-X21MT
X.21 DTE
10 ft (3m)
Male
CAB-SS-X21FC
X.21 DCE
10 ft (3m)
Female
CAB-SS-530MT
EIA/TIA-530 DTE
10 ft (3m)
Male
CAB-SS-530AMT
EIA/TIA-530A DTE
10 ft (3m)
Male
Has anyone encounted a similar issue?
I know you can use smart serial to smart serial connection; however, that's not what I'm looking for,  this is for a test bed.
I found a EIA-530A DCE cable (CAB-SS-530AFC), although it's not on the NIM list and may not be compatible.
And lastly, since the CAB-SS-530AMT is a balanced serial connection is it using electrical signalling RS-422-A?
Many thanks
Anthony
0 Replies 0
