CAD Drawings
Please i hope you can help me, I need the CAD drawing (DWG, DXF, or STEP) for the followings components:
-          IE 3000-8TC
-          PWR-IE65W-PC-AC=
Thanks in advance, regards!
7 Replies 7
Mark Malone
as far as im aware Cisco don't supply CAD drawings only visio icons
https://www.cisco.com/c/en/us/products/visio-stencil-listing.html
ok... =(
thanks!
Good day, Im loking for CAD or Visio Stencil for IR8300 product family, I couldnt find it on the Cisco Stencil link.
Any help?
nsipes
Try looking at Rockwell's cad files for the 1783-MS10T https://raise.rockwellautomation.com/RAConfig/resultsComponents.asp?CID=FA23414D7CD04D1EA7612ABF8939E883 or other models for other IE3000 blocks.
Contact your Cisco account team and ask them to request the drawings from the product managers. Initially, they will push back and ask why you need them instead of Visio drawings, so have a rationale ready. It will also help if you can link this request to a recent or upcoming purchase (this is true of any request you make of your account team).
Disclaimers: I am long in CSCO. Bad answers are my own fault as they are not AI generated.
tharindup
I need the CAD drawing (DWG, DXF, or STEP) for the followings component.
PWR-IE480W-PCAC-L
I need the CAD drawing (DWG) for the following component.
PWR-IE480W-PCAC-L
